Old September 3rd 2005, 19:01
bow's Avatar
bow bow is offline
just take the baffling out of the stock exhaust then weld up the hole where you had to cut
Old November 12th 2007, 16:06
redhot redhot is offline
Are there any updates on this?
Want a "stock" looking exhaust for a 2.0 liter GB engine. Must exit through the stock location.
Old November 12th 2007, 16:29
Cohibra45's Avatar
Cohibra45 Cohibra45 is offline
redhot,
Chris at Tangerine makes a complete header with an muffler that can accommodate your needs. Very nice and well built. It does cost, but, it is probably the best you can get .
http://www.tangerineracing.com/Super_Header.htm
Take care,
Kelly (Cohibra45)
Old November 12th 2007, 17:07
Hi,
Thank you for the link!
That was a very steep price, but of course quality costs. But cant afford that one as it is...
Thoug: CSP has a Type4 in Beetle muffler, but didnt fint the corrensponding header/exhaust system
Old December 3rd 2007, 10:34
Found one here:
http://www.yunis.de/klaus5/en/SD_english.asp
Anyone tried it?
Old March 19th 2010, 08:41
This picture is of a Memminger Feine Cabrios car - anyone recognize the muffler, or could it be a one-off?
/Limo_wei9.jpg
Old March 19th 2010, 12:03
johnnyvee's Avatar
johnnyvee johnnyvee is offline
that kind of looks like a old style exhaust canister, you have any more pics of the car's engine setup
Old March 21st 2010, 05:56
Arnoud's Avatar
Arnoud Arnoud is offline
Why don't you get the Vintage Speed stainless steel 'Superflow' exhaust which I believe is exeptional value for money-hey even german tuners(Wilke for ex.)sell them.
http://www.youtube.com/watch?v=VzR-1...eature=channel
Regards,Arnoud
pre-'55 oval:stuffed in a barn
1972 1302S(Cali Type4 EFI)
1973 1303S(soon with Oettinger TSV2000)
Old September 4th 2010, 08:31
The Vintage speed is similar to that of Klaus tuning, CSP and many others. Looking at some pictures it seems that they hang pretty low, reducing the clearance to the ground.
But a merged system that still exits out the rear cut-outs is not that available. I would love a design like the CSP supercompetition for a type4 engine. This also removes the large mufflers to the wheel arches, meaning not problems with clearance.
Perhaps someone would chime in with some exhaust theory: does it really matter that much on an close to stock 914 2.0 engine?
Old September 4th 2010, 16:07
vdubzack's Avatar
vdubzack vdubzack is offline
A better flowing exhaust will make a difference, even on a near stock 2.0 It's enhanced flow will allow for cooler head temps and lower the chance for dropping valve seats.
Old September 6th 2010, 07:28
The best ehaust for a street/semi-competition motor is a 4-2-1 with 30"+ primaries and similar secondaries depending on the state of tune. However, the architecture of the flat 4 boxer engine doesn't lend itself to this sort of design so you get the compromise 4-1 layout with a merged collector at best. At least CSP and the like have got the 4-2-1 concept firmly in their blood to attempt it on the VW flat 4 engine but the spaghetti pipework has to be an expensive work of art. A 4-2-1 arrangement should give a more flexible engine that may be down 1 or 2 bhp on the 4-1 unit but that flexibility shows itself in A-B times and economy.
Old September 13th 2010, 06:15
vdubzack's Avatar
Originally Posted by kakarottt View Post
Turns out that in the state of Maryland, It is illegal to have any sort of exhaust modifications.. So I need to find a stock looking exhaust for my 2110. Or at least an exhaust that sticks out the stock holes or is relatively hidden.. Any suggestions?
It is also illegal to lower or raise your car more than 2 inches.
Not actually illegal to have a modified exhaust.
But it has to be enclosed by body panels. So most Fat Boy and almost all merged exhaust systems will fail initial as the muffler is not below car but behind it. Plus if your 2110 is type 1 based i would go for this one,
http://store.vintagespeed.com.tw/ind...mart&Itemid=80
as the price and value is there. And for those( oh its Chinese junk ) people. there is a lot of stuff being manufactured there by companies that dont even no for what car they are making stuff for. These guys are enthusiasts. and test and run everey thing they make.
Old February 13th 2011, 08:15
So; how does the original Porsche systems work? It does not look like they are using the 4 into 1 systems most VW performance exhaust use, or do they have a collector inside the muffler? (both 914 and 911?)
Old February 14th 2011, 09:39
This should be Remelle's exhaust, as for Klaus, he said he only sells his exhaust system with his engines!
/Limo_wei9.jpg
T4 2666 1303s
Old February 15th 2011, 09:01
The porsche is a 6 cylinder engine so 4 - 1 cannot work As with most 6 cylinder engines the scavenging effect tends to work with the coupling of each set of adjacent cylinder so you should get 6 - 2 - 1 as shown in the photo. The same arrangement on 6 cylinders work whether its a straight 6 V6 or flat 6. On a 4 cylinder to get scavenging the cylinders are coupled 360* out so that on an inline 4 with a firing order of 1,3,4,2; 1 is coupled to 4 and 3 couple to 2. The same applies to V8s so that is why the exhaust plumbing ends up looking like spaghetti.
then you start to consider single plane crankshafts..............................
