Old August 22nd 2006, 09:36
flat flat is offline
One other thing, with the Boxster S rotors, the disk-to-hub retaining screws don't line up. Also, last time I checked the Boxster S rotor was about double the cost of a 86T.
www.vdubengineering.com
Old January 16th 2008, 13:39
matara's Avatar
matara matara is offline
Lanner,
Can you tell us if we should be getting the Boxster S disk with a 67mm height or a 70mm height?
Old January 23rd 2008, 22:09
I'll try and dig them out this weekend and measure....
Old May 30th 2011, 05:06
matara's Avatar
Any luck finding out which height is should be Lanner?
Old May 30th 2011, 10:25
Yup, it's the 67mm ones (2000-2004 Boxster S)
Old July 12th 2011, 21:13
vdubfund's Avatar
vdubfund vdubfund is offline
Hey
Guys
I am currently running Boxter S rear discs 964 2 pots in the rear
Am also using Lanners spacers
Oh this is on a 64 swing axle bug.
Needs slightly more than the 3mm though. But works great
Using 944 MC outlets are reversed. Rears are fed off the front port and fronts off the rear port.
Dean
Old July 13th 2011, 08:33
Originally Posted by vdubfund View Post
Hey
Guys
Dean
I have easily and successfully added 944T/928S4 calipers to 944/924S N/A arms with 944/924S discs(rotors). The disc thickness is less than ideal but periodic monitoring will ensure that the pads don't wear down too far to pop the pistons. I anticipate fitting 299x24x71 944T/928S4 discs when the pads wear down that should comfortably correct the disc thickness issue. I also expect some shimming to still be required to centre the disc.
The rear ports (closest to the pedal i.e.23mm dia) should feed the front brakes regardless. The front ports i.e. the 19mm dia feeds the rear brakes.
