Old November 22nd 2006, 12:48
Originally Posted by Bugger View Post
Thanks, how do I find out which model my engine is? Sorry for the newbie questions, this is obviously my first bug. It seems to redline higher than that, like when I am accellerating just for it to feel and sound like time to shift without pushing it i go to like 5k rpm. I will take it easier I guess, Also my tach. seems shaky at higher rpms, like above 5k what could I do to fix this?
Don't worry, factory HP and TQ numbers stop there (this is an average), but the engine will rev higher... it just doesn't make any more power.
To cancel the noise (shaky tach) you need to put a resistor ( don't remember the OHM right now) inline on your ground wire.
Old November 23rd 2006, 12:13
Bugger Bugger is offline
on the ground to the tach, not the sender wire?
Old November 23rd 2006, 12:35
Okay I found the shaky gauge answer. A diode needs to be connected to the signal lead if you have points of pertonox type ignition. So the signal wire that goes from the coil to the back of the tach needs this diode. The diode is #1n4005 from radio shack or other supplier it needs to go with the silver band towards the tach in the wire. Hopefully that works, I will try it tommorrow and let you know.
Old November 24th 2006, 23:16
The diode worked wonders, it smoothed it out, and now the tach says I actually do redline close to 4000 rpm which is good.
Old November 25th 2006, 01:04
freekazoid freekazoid is offline
I'll probably have to pick up one of those myself, thanks.
Old January 18th 2007, 03:46
PM'd ya Bugger about what model vdo fuel gauge your using.
Old January 20th 2007, 08:28
65Cabby's Avatar
65Cabby 65Cabby is offline
I've used one of these multi digital guages in the past, they have the advantage of memory so you can always see what was your highest temp.
They come in black too.
