Old March 19th 2007, 09:03
Zman Zman is offline
man (Gary)
Gary Zimmerman
69 German Looker T4 2270 Raby Kit
Old March 19th 2007, 14:56
1303R's Avatar
1303R 1303R is offline
whats the side cover thats needed then?????????????? i'm getting chuffed off with this. was surposed to be a straight forward jod, got all bits from same source, so thought i'd be ok. anyone wanna buy a 914 box with some of the bits needed to convert
Old March 26th 2007, 14:41
1303R's Avatar
right. after pulling gearbox apart, looks like the shift rod pieces i got with conversion parts, are the same as whats in box already!! only thing i need to change is the long shift rod that sticks out the nose cone and thats the only bit i aint got ok. so now i'm gonna cut the 914 rod and weld the 1303 rod to it. hopefully making something i can use. the sun's out in england now, we dont get it much so really missing my bug one way or another this sucka's getting done
Old March 27th 2007, 10:36
1303R's Avatar
hmmmmm, ok so wanna put this back together, shift rod looks pretty good. only prob now is my manual dont have any info on setting up the backlash. had the one gasket on it, heard most have two, does this mean i want to put back three? any one got any insight? please? thanks al
Old March 28th 2007, 13:58
Without measuring it, I would suggest doing the following. Look at the wear patterns on the ring and pinion gear. It should be in the middle to root. If your wear pattern is there, then put it back together with the same number of gaskets as it came apart with. You should be fine.
Gary Zimmerman
Old May 16th 2007, 11:15
1303R's Avatar
well my box is all in and hooked up, thanks for the advice. now what i need to know is, does the spigot bearing need fitting in the flywheel if using a type 4 flywheel? engine is a wasserboxer but same flywheel. not using a 914, jus standard bus one.
Old May 22nd 2007, 03:17
Pablo Pablo is offline
I think you will find you need a 914 flywheel with the Porsche box, it has a longer reach into the gearbox and has the support bearing already in it.
Old May 22nd 2007, 04:38
1303R's Avatar
thanks for the reply. i'll have a go with me measuring stick to see what i can work out once the engine's back together. cheers
Old May 29th 2007, 10:10
914 flywheel
Pablo is correct, the input shaft is longer on the 914 transmission, so get a 914 flywheel have it machined (lighted if desired), but it already has the bearing and will work perfectly. If you can get it balanced with the crank you will not believe how smooth the engine will be. I purchased one from Jake and he balances it down to which bolt on the clutch goes into which hole as part of his engine kits as well as the clutch itself. It is amazing how smooth it runs with his balance job. But if you can balance it with the crank, well worth the effort and the extra $ IMHO.
Gary Zimmerman
