Old June 7th 2007, 15:48
mccarthy500 mccarthy500 is offline
I went with the thing shop they already came in and im happy with there customer service. they were very nice. for two thing output flanges it was 90 shipped and they arrived in a couple days.
Old June 16th 2007, 11:38
Eliasson Eliasson is offline
Hi everybody
You couldnt use 944 T with typ 1 or other VW CV joints. They have 33 splines and the 944 T driveshaft have 25 splines. I made the mistake myself and had to buy another pair of drive shafts from a 944N/A. The 944N/A have 33 splines and could be used to any 33 splines VW CV. Both have the same lenght 52cm.
The 944T driveshaft would be a good choise if you use a Porsche gearbox. I will save my Turbo shafts until then .
Old August 8th 2007, 20:52
speedy's Avatar
speedy speedy is offline
just as a piece of info , i was told by a reputable vw tuner to leave type 1 cv's on a irs box output as a weak point , 20 mins to replace as opposed to sending the weak link into the box itself diffs etc and gears are far more expensive and time consuming to replace , makes perfect sense to me .
woop woop
67 2276 turbo
64 ghia 1776
zx7rr
Old August 9th 2007, 00:05
I would a agree with that. I broke a Quaife output shaft, the Kombi CVs were fine, no damage to them at all, it was my fault that it broke, but CVs would have been easier to fix.
Old August 11th 2007, 05:14
Bruce2 Bruce2 is offline
How many broken Bug CVs will it take to change your opinion?
Old August 12th 2007, 00:33
speedy's Avatar
don't know , i personally have only bust one so far , a couple a year is fine buy me if it saves my box
woop woop
67 2276 turbo
64 ghia 1776
zx7rr
