Old July 3rd 2007, 14:56
MrSelfDestruct MrSelfDestruct is offline
Originally Posted by gonebuggy View Post
Well since this is about brainstorming ideas.... how about a 16 valve engine, with a desmodromic valvetrain?
in case you are unfamilier:
http://en.wikipedia.org/wiki/Desmodromic_valve
or maybe solenoid operated valves?
http://rbowes1.11net.com/dbowes/index.htm
get those ideas flowing!
That desmodromic is a sweeeet idea!
How about that variable valve lift system Honda used (still does?) in those civics and cr-x's? Apparently (correct me if I'm wrong) when the engine hits a certain rpm, the fulcrum point on the rocker arms changes and effectively changes the ratio of the rockers (i.e. 1.1:1 to 1.25:1 quoting bug rockers).
Porsche bits and type 4 power.
In Germany, they do it right.
Old August 29th 2007, 16:09
DrFrankenstyle's Avatar
DrFrankenstyle DrFrankenstyle is offline
Also jumping into the thread
From my clubmates I get any number of ideas and opinions about engine power. But good solutions for getting that power into actual SPEED are fewer... My stock engined, 15-inch rimmed w/ 195/60 tires, T1-69 revvs like crazy at 110 kph... If I had a 100 HP instead of my current 55, I don't think my actual speed would increase, I would only have to rev even more??
I have also heard NOT to experiment with ACVW transmissions without really knowing what you're doing. I don't.
So, more HP into actual street speed... How?
Kustom, pinstriping, DIY culture - www.frankenstyle.se http://www.myspace.com/frankenstylegbg
Old August 31st 2007, 03:35
Blitzkrieg_ Blitzkrieg_ is offline
The best way to real power is a Type 4 engine, just do the heads correctly the first time around and it will last and last, bullet proof bottom end also
Old August 31st 2007, 14:03
Just how f$st do you want to go?
