Old November 1st 2007, 16:00
Did you put a tiny washer under the plastic pivot ball cup that the 901 clutch arm pivots on ?
This tiny washer gave me full actuation of the clutch. I can put the clutch pedal to the floor with the 901 TOB and 228mm PP.
Old November 1st 2007, 17:36
DORIGTT's Avatar
DORIGTT DORIGTT is offline
I love you guys... saving me all that frustration!
You want to come install the thing for me?
Hey 1302R, how much power are you producing?
Old November 2nd 2007, 13:38
1303R's Avatar
1303R 1303R is offline
hi. no didn't put washer under pivot. will do next time engine is out thou!
Old November 2nd 2007, 13:43
1303R's Avatar
hi. i think i'm putting out 180bhp. think there may have been a missmatch of parts with my 215mm set up as the pedal was very light and when removing pressure plate i did realise that compared to the 228 set up the inital clamping was no where near as much! i got the flywheel second hand and had the 7mm bolts, got new clutch 215mm. so not sure what was wrong?
1303r
