Old November 20th 2007, 23:25
flat flat is offline
Are they made from steel?
Yeah, the 924 ones are steel and the bearing cap is seperate (2 piece). The 944 ones are aluminum and the bearing cap is part of the backingplate (1 piece).
www.vdubengineering.com
Old November 21st 2007, 00:35
Thanks Lanner
Old November 25th 2007, 17:53
The pics there are for 944 aluminum backing plates that have been machined to retain the shortaxle bearing. My concern with that is that the 944 backing plates have a grease seal on them that was designed to retain grease. When you put them on a swingaxle car, the oil leaks a little. The advantage of the 924T ones is that you can use youe swingaxle bearing cap, with the oil slinger. Anyone out there use modified 944 ones on a swingaxle? Any issues with oil seepage?
Old November 25th 2007, 19:29
vw62rag vw62rag is offline
looks to me like the oil seal from a bearing cap will fit right in to that 944 modified backing plate, i dont see the problem? can you post a picture of the oil slinger your talking about please?
Old November 25th 2007, 19:39
Old November 25th 2007, 19:45
i only run the 61 - 66 one. thats the one i need.
Old November 26th 2007, 21:16
vw62rag,
Yeah, I was talking about the oil slinger on the long-axle long spline setup (1968 bug and all year T3's). I've always recommended the 924 parts, but now that they are getting harder to find, I will look into using a modifed 944 backing plate.
Thanks for posting the pics, and keep us all up-to-date on the progress.
Old November 27th 2007, 00:09
is this the oil slinger your talkin about?
Old November 29th 2007, 00:54
danielzink's Avatar
I tried going that route with the aluminum backing plates at first......trust me it doesn't work. I seeped gearbox oil everywhere after one run down the highway and the gear oil got warm and thin. It was a huge mess.
As stated - it's worth the time and effort to haunt the salvage yards etc. to find the correct backing plates. Do it right once and you'll be much happier.
Dan
65 notch 2300cc type4
www.danielzink.com
Old November 29th 2007, 01:24
i dont understand? why and were would it leak from? i mean you put the same oil seal in the aluminum backing plate as the bug end cap? please explain
Old November 29th 2007, 22:49
danielzink's Avatar
Okay..........
here's what it looked like with the aluminum backing plates:
Please note how deep the splines go in relation to where the slinger will sit and the "lip" on the blue seal......That's your problem...
Here's a pic with the slinger on.....I could just push the slinger on and past the blue seal with no problem...it's not a correct fit. That's where it leaks...and it leaks like a sieve.
Now notice how everything works when installed "correctly" - no more leakage....
If it was as easy as slapping the aluminum backing plates on these axles and bolting everything together and it all worked right - MBT wouldn't be making repro backing plates and we wouldn't be searching every Porsche breaker in the country for these steel ones.
Dan
www.danielzink.com
Old November 30th 2007, 00:08
Did you have the O ring on the axle behind the slinger? I've fitted lots of later model drums and backing plates to swingers with no problems. On short axle cars I only needed to cut down the snout on drum.
Old November 30th 2007, 17:30
danielzink's Avatar
Think in the third picture you can actually see the o-ring.
Dan
www.danielzink.com
Old December 1st 2007, 14:35
i emailed the guy ( the one i got the pictures from ) and he said this.
Oldspeed in Paramount Ca. can machine the aluminum ones for you, I paid $80. It was about 6 years ago, maybe his price is different. Talk to Russell. They are the ones in the picture. I have them on two cars and don’t have a problem with leaks, seals are 6 years old. They seal just like an early axle. The picture of the hub was just to show how the front was machined down and the rear for a bit of extra clearance on the drum mod. Maybe the people who have leaks didn't machine deep enough for the backing plate to go over the bearing. Are these going on a bug? My friend did the same thing in 1992, never had a problem. It's a lot of brake for a bug. I have front and backs on my bus, first time I drove it I almost supermanned it through the safaris. I will look if I have and axle tube and axle to take pictures bolting it together. It might be cheaper if you do it the other way, you can save on the machining cost and just bolt on the steel. I've never tried that one.
