Old May 4th 2009, 15:30
jmd's Avatar
jmd jmd is offline
Trevor,
Thanks for the post. I am working with the 901, so I am not sure the total difference between mine application and yours but it seems that your 'redrilling' might be something that I can look at. Originally the gent that built my trans thought he might have the output shafts to get the connection to the 944 cv's but later discovered that he did not. so the two questions I have are 1. Are the output shafts difficult to remove/change? 2. Is there a 901 application of this mod that someone has done succesfully?
thanks again for sharing your experiences.
Old May 4th 2009, 15:38
trevorbrady's Avatar
there's a single bolt in the centre of them (17mm/19mm, I can't remember) and they just "plug out". Installation is the reverse of removal, as they Haynes manual says.
Old May 5th 2009, 13:02
jmd's Avatar
jmd jmd is offline
trevor,
that got me right where I needed to go, thank you.
As you mentioned the Haynes is there any chance you
have one and if so does it tell you the torque specs for
when I put these back on?
thanks for all the help.
Old May 5th 2009, 15:24
sorry, no torque specs
Old May 15th 2009, 16:57
jmd's Avatar
jmd jmd is offline
just dropped off my 901 flanges to the machinist with my 944 axle as reference.. we will see how it all goes. thanks for all the insights.
Old June 30th 2009, 11:57
jmd's Avatar
jmd jmd is offline
so I have been told by my machinist that there is no way that he can drill these 901 output flanges, that the material is too hard?! How is this getting done? Trevor, any insights on this as you've had your's drilled? So now I am back to square one. Getting the 901 output flanges to mate up with the 944 turbo cv's? I am starting to hit a wall here, as this is the only thing keeping me from bolting this all together?
Anyone?
Old July 1st 2009, 05:04
I find it difficult to comprehend that the material is too hard? the only problem that I can source is the fact that the 901 appears to have a 4 bolt/2 dowel arrangement - see http://www.aircooled.net/gnrlsite/re...he5spdconv.htm that gives a good build up of the installation.
Old July 2nd 2009, 08:23
flat flat is offline
I'ts easy breezy, press out the dowels, drill and tap for M8 keensert (I think it's M12x1.25 IIRC) and put in the keensert. It's not hard material and a standard HS drill does the trick.
Good luck..
www.vdubengineering.com
Old July 6th 2009, 17:29
Bug@5speed(US)'s Avatar
Jmd,
Info sent, sorry for the delay..
VR
Alex Olaverri
Email: Bugat5speed@yahoo.com
Tele: 973 204-5463
Old August 4th 2009, 13:22
jmd's Avatar
jmd jmd is offline
solution found.
Gents.
I have figured out a simple solution to my problem.
- Ditch the large late 901 output flanges (4 hole 2 pin)
- Source early small diameter 901 output flanges (6 holes)
- the only difference's between these is a slight length difference and a diameter difference at the primary shaft, meaning that this has to be turned and re-polished to remove a minor amount of material. then it plugs right in, matches with the 944 stuff end to end, and will allow the use of 944 axles...
More info coming once I get it all dialed up.
Side shots:
Flikr Shots:
my Flikr Album
thanks to everyone for helping provide information. I plan to fully document this process to hopefully help those after me save a bit of time and money...
Old August 4th 2009, 13:45
chug_A_bug's Avatar
thanks for the Info Jmd
can't wait to See your write up, and when I'm ready to go with 944 arms and set my 901 up I know where to come read about it.
thanks again
74 Std. GL
08 Vw rabbit
18 WR250R
07 Chevy 3500 Dually
Old January 6th 2010, 17:18
jmd's Avatar
jmd jmd is offline
final solutions
Guys,
I just wanted to follow up to this post with some installed images incase anyone else is interested.
Starting here and moving forward in the images shows the two output flanges compared and then some measurements to help others trying to solve similar problems.
http://www.flickr.com/photos/3931035...7619575747670/
Again the solution was to source a pair of earlier smaller diameter course spline output shafts and have the base shank turned down by a mil. they fit like a glove. and allow plug-n-play for 944T axles.
Hope the pictures and such help.
Let me know if you have any additional questions.
Also thanks again to everyone for helping me resolve this issue and being supportive.
