Old February 6th 2008, 19:49
yetibone's Avatar
yetibone yetibone is offline
Thank you for all the complements, and kind words fellas. It was a bona-fide pain in the @$$ getting the car to this point, but the last month of driving, and dialing the car in has been duly rewarding. It drives so much different than it did on New Years day, it's unbelievable.
I squared up the suspension without adjusting anything to a specific setting, except the toe. All I wanted to do was make both sides equal, but with the correct toe angle for a Superbeetle, so the front camber is -0.6 degrees, and front caster is +2.9 on both sides. It feels like there's no real center to the steering. If I turn a few degrees either way at highway speed (like passing on a four lane road for instance) the steering wheel will stay there. If I'm driving straight, it stays straight, so there's a 'won't return' area in the center range of the steering wheel. I'm going to increase the right front caster to +3.0, or +3.1 degrees to see if that will center the steering against the crown in the road surface.
The rear ended up at +2.3 degrees camber, and 1/32 toe in. I also raised the ride height at least 2" in the rear, which made a very positive difference in the way the car drove. It feels so much more stable at speed. Totally the opposite of what I expected, but I guess having my car so close to the bumpstops didn't give the torsion bars enough working range, and bottoming out on the bumpstops upset the back end to much. I'm certain the chassis can truly outperform the aerodynamic capabilities of the car. Kinda scary.
Yetibone
'71 1302S 1.8
'73 1303S 2.3
'83 928S 4.7
Old February 6th 2008, 21:40
flat flat is offline
Great car!
May I ask how you are measuring your caster? I've been looking at purchasing a bubble style gauge, but would appreciate some feedback or suggestions.....
www.vdubengineering.com
Old February 6th 2008, 23:26
yetibone's Avatar
I have use of Hunter P411 at work. It's a great situation for me because I can make adjustments, and relate the driving difference to the measurements on paper.
I haven't looked into finding a bubble gauge. Does any tool mfg still make those? I remember my Dad had a Bear hub mounted bubble gauge, slip plates, and toe pointers maybe 15+ years ago.
Yetibone
'71 1302S 1.8
'73 1303S 2.3
'83 928S 4.7
Old February 7th 2008, 00:27
I have a stock cambered 1303 and its very low so the camber is way off, I'm getting good wheel return still. Is your steering box or rack not too tight?
Old February 7th 2008, 02:44
My exct same thoughts; adjusting screw of steering box turned in too far?
Old February 7th 2008, 07:55
yetibone's Avatar
No. I would have felt that, and known the difference. The steering components have no mechanical binding whatsoever. Anywhere.
Yetibone
'71 1302S 1.8
'73 1303S 2.3
'83 928S 4.7
Old February 7th 2008, 08:50
karol karol is offline
what is the colour? Looks like the same colour as mine
Old February 7th 2008, 13:26
yetibone's Avatar
Porsche Iris blue. The code is L39V
Yetibone
'71 1302S 1.8
'73 1303S 2.3
'83 928S 4.7
Old February 7th 2008, 16:48
Thanks hun. great to see a bug the same colour as mine
Old February 7th 2008, 22:07
yetibone's Avatar
My pleasure.
Yetibone
'71 1302S 1.8
'73 1303S 2.3
'83 928S 4.7
Old February 9th 2008, 20:54
Rob's Avatar
Rob Rob is offline
Looking good Yeti !
What are those mirrors ?
Rob.
Old February 11th 2008, 00:33
yetibone's Avatar
Originally Posted by Rob View Post
Looking good Yeti !
Rob.
Thanks.
It's just a stock one painted black, only on the driver's side. It's the one that came with the car, but with a new piece of glass I got out of a cheap "made in China" repro. I put the glass, and plastic ring in the mirror body with the glass taped off, primed and sealed it with Lesonol epoxy sealer, and painted with DuPont Centari gloss pitch black.
Oh, yes. I ground all the chrome off the pieces first.
Yetibone
'71 1302S 1.8
'73 1303S 2.3
'83 928S 4.7
Old February 21st 2008, 17:12
Evandro Marola's Avatar
Evandro Marola Evandro Marola is offline
these wheels are of 15 polegadas?
