Old June 15th 2008, 20:14
Some update pics
Progress ...
Old pan vs new
Old June 16th 2008, 03:23
Why did you end up going with A/W intercooler? I'm really in a toss up, I think the A/W might be better on the street, but the added complexity and weight I'm not sure makes the trade off worth while. What did you come up with on your search?
Old June 16th 2008, 21:10
petevw's Avatar
petevw petevw is offline
Sandeep, looking good.
At this rate, you'll be back ont he road before the snow falls.
'72 super
'65 bus
'52 split
Old June 18th 2008, 11:15
I used the A/W due to size restraints but that was to cool the original 2.0 and TD04-13T turbo.
The new 2.4 with GT3071R will overpower my current system (390cfm capacity) easily.
I wanted an A/A but could not figure out how to package it well, until Wally showed pics of his system. That is the way to go about but I will have to redesign my intake plumbing.
Old June 18th 2008, 11:16
That is the plan !
Old June 27th 2008, 21:39
Update
I've stripped the frame of everything that was rusted out and removed the front and rear suspension.
I'm building a proper 915 front mount now ... something that looks factory and will confuse the techs if I ever have the car up on a lift.
I plan to use the stock trailing arms (refurbished) with urethane bushings and dipped (zinc chromate) stock spring plates.
I think I have found a coilover (QA1) to use with relaxed trailing arms but will have to check if they fit.
I need to strip the rear arms and prepare the chassis for a coat of POR15 ... hope to do that this weekend.
Old June 28th 2008, 00:21
Keep up the good work!
Old June 28th 2008, 03:32
chug_A_bug's Avatar
NIce Job Sandeep
Keep the Pics coming
74 Std. GL
08 Vw rabbit
18 WR250R
07 Chevy 3500 Dually
Old June 28th 2008, 08:15
gonebuggy's Avatar
You're committed now bro!
Looks good, and I like the plans you have in store for it! Keep up the good work.
1970 Bug
2110cc. ???Whp, ???Ft/Lbs
Old June 28th 2008, 08:23
Rob's Avatar
Rob Rob is offline
Wow man, when you dive in, you DIVE in !
Good work!
Rob.
Old June 28th 2008, 11:56
DORIGTT's Avatar
DORIGTT DORIGTT is offline
How much 'massaging' did you have to do in the crotch area to fit the 915 in there?
Also Sandeep, do you have pics of your A/W setup?
Old June 28th 2008, 14:39
I'll take some pics of the 'crotch area' but I notched it enough not to harm the torsion bar area. The 915 bellhousing surface sits about 6mm further to the rear than the stock gearbox, no adapter parts for the 915 required as I built all the peices myself.
Old June 29th 2008, 10:58
Rob's Avatar
Rob Rob is offline
Sandeep, what kind of welder do you use ?
Rob.
Old December 31st 2009, 14:29
Christmas break update
Having 2 week off really helped
I welded up the pans and sandblasted them, and then acid etched with phosphoric acid.
Some POR15 ..
And then some "tie coat" primer
And then two coats of Tremclad yellow to closely match the body
Old December 31st 2009, 14:32
I'm almost done the top now, just waiting a few days for the POR15 to cure before adding the tie coat primer and tremclad yellow.
Then I can start assembling the pan
