Old August 7th 2008, 05:01
Angelo Amato's Avatar
hello Kai,
no, did not find this at all, the nylatron bushes were identical it every way to the stock rubbers mounts including all the correct grooves/chamfers/profile, etc on them.
i didn't take a pic of them as they were black and you would of been able to thell the difference to stock ones.
installation was the revserse of removal, as they say!
Angelo
Type 3 Fastback
Old September 24th 2008, 00:37
Clatter Clatter is offline
How did this work out?
Can't help but wonder if it was a lack of caster up front.
Type3 has no way(?) to get more caster....
Old October 5th 2008, 18:34
fasty
Hi Clatter,
sorry for late reply....
not done much really this year with it, lots of other things going on.
the solid mount for the rear subframe were done and i must say is a MUST on hi po type 3's. even tho the rubber ones were A OK, they are very soft.
this has made some improvement but not completely happy yet. going to turn my attention to the front.
going to try and turn the camber to see what effect this has, bearing in mind this also afftect the cast a little.
the car is not radically low, so still no convinced.
also going to get hold of some normal ish rubber/wheels prob 15" see if that changes owt.
Angelo
Type 3 Fastback
