Old November 12th 2008, 12:27
Superman
Originally Posted by kuna View Post
link to my picassa album with photos, I have no idea why they aren't working.
It's because the directory (_La1eAqcYaPA) in the link has the _underscore_ which makes the forum software see it as a script and a possible threat.
Code:
http://lh6.ggpht.com/_La1eAqcYaPA/SQ3Iq6_FdwI/AAAAAAAAADg/KTac2RGyzrs/s640/IMG_7575.JPG
Old November 13th 2008, 04:31
blitzvw's Avatar
blitzvw blitzvw is offline
Does the speedo cable from a Beetle/Type 3 just fit straight into the 924/944 speeedometer?
Blitzem with Type 4 power
Old November 13th 2008, 11:50
helowrench helowrench is offline
It should, as they look incredibly similar, but I have not physically tried it myself.
Rob
Old November 13th 2008, 15:13
The square drive does but you will have to come up with some other way to retain it as the collar doesn't fit... Thinking about it, maybe a 924 cable would fit?
Old November 13th 2008, 16:14
I know that a 924 has the same type of end on the wheel side. square/through the spindle/etc and it should be about the right length.
Rob
Old November 14th 2008, 03:37
blitzvw's Avatar
Okay sweet!! Thanks guys! My Type 3 will be getting a 924/944 speedometer in the centre hole...
Kuna, your dash is looking very cool!
Old November 15th 2008, 05:21
blitzvw's Avatar
The Type 3s also have a tube style sender. I wonder if the 924/944 fuel gauge would be compatible??
Old November 18th 2008, 15:21
kuna's Avatar
kuna kuna is offline
1303 speedo cable works fine with 924 speedo (pre 1980, I have 1977 gauges) the problem is that gear ratio is different than beetles, 60km/h on the speedo is about 50km/h, I have checked that with drill on cerain rpm
Old November 19th 2008, 14:47
It's a direct drive from the front wheel for both cars so it all depends on what size tyres you run...
Old July 29th 2009, 03:51
blitzvw's Avatar
I have a 924 speedo that I'm fitting to my fastback and the cable fits and screws on perfectly
