If some is good and more is better, then too much should be just about right! |
Small step. it's on wheels again (only two for now)
![]() Now it's on it's wheels I could adjust the height and found out that the coilovers where hitting the drive shafts. So back to the drawingboard ![]() ![]() ![]() The fuel system is almost complete. this week I received the pumps, pumpbrackets and regulators. one set for the carb's and one set for the nitrous. ![]() Paul.
Isn't that a bit drastic?
With the 944 parts and maybe some Elephant racing heim joints, there is ample camber adjustment possible. I was amazed how much actually, now I could freely move the arms without the torsion bars hindering...(coil overs only like you have now also) |
I almost went there awhile back, and may still.
Might as well install some real height adjusters in the torsion while at it >;-) Here was my inspiration for adjustable inner pivots http://tr6.danielsonfamily.org/TrailingArmKit.htm Would need some redesign for our use, but the large dia inner "crush tube" in the bushings should make it pretty sturdy. Anyone offhand know the proper shock length with aluminum arms in a T1 or T3 with std upper mounts? (T3s upper mounts are double shear BTW) Last edited by piledriver; May 7th 2016 at 00:24. |
https://www.iemotorsport.com/bmw/E30...bkit-lock.html Guy i know used these on his early bay and they work great.
Zero camber @ the lowest position. now i have to check the camber when it's a bit higher.
As you have cut that much away you do a similar mounting for the swing arm that 944s use, google some images and you will see what I'm getting at, you could even have different mounting heights for the pickup point
I'm sorry if you've already stated this, but what steering rack is that out of? Nice work!
johnL (aka H2OSB) '74 1303, Outlaw sedan (with a GL flavor) |
Thanks, the steeringrack is from a rhd Hyundai
Made 2 driveshafts out of 4 VW Golf shafts.
Yesterday I mounted the T1 and T2 CV's and fitted them on the car. ![]() ![]() ![]() Paul.
Not sure why I hadn't read through this entire thread before
but you've done amazing work!H2OSB
The chassis is ready (so far) so the body is on again.
The front is nearly ready.
fitting the Porsche suspension ![]() And it's on 4 wheels again.
| Currently Active Users Viewing This Thread: 5 (0 members and 5 guests) | |
