Old February 21st 2017, 06:58
Interesting!
282 kW is at the wheels I presume? Thats 383 hp at the wheels, which is about 430 crank hp (+12% average for that gearbox i think) at 27 psi. Seems low for that turbo, engine and boost setting..(?)
It also still seems laggy, even without RPM at the x-axis. Do you also have the RPM dynosheet?
Seems another issue causing the laggy-ness I think? Wastegate control? Pre-turbo leak? The latter may also effect the total hp.. and could be detected with a speed sensor, but not many people use those ;-)
Old February 26th 2017, 08:32
graham's Avatar
graham graham is offline
Thumbs up
Nice Progress Steve..
Good to see you have those stents fitted
gee dub
Old March 2nd 2017, 22:42
282 kW pretty good for a 2 litre motor. I hurt a piston at an event on the weekend, Im going 2.1 fully forged motor now.
Old March 3rd 2017, 16:25
Ah, 2 litre, that explains a lot. I agree, then the torque plots looks much more logical. Sorry, I had forgotten that.
Sorry to hear about the piston hurt. Fully forged definately seems like the way to go with these hp levels
Old April 5th 2017, 22:28
OK motor is stripped, burnt piston and a twisted conrod, so stroker crank forged rods and pistons and doweled water jackets. The stroker should be good to bring on the turbo sooner and it will be able to revved higher so I will have a broader powerband, same motor combo is good for 400 kW at the wheels in AWD drive cars.
Old April 13th 2017, 06:12
petevw's Avatar
petevw petevw is offline
Whoa, nice build!
'72 super
'65 bus
'52 split
Old April 15th 2017, 15:06
Nice updates! Still on the GRX3076R ?
Old April 16th 2017, 21:49
Thanks Petevw
Still the same GTX3076R turbo but with the .63 rear housing, not long now
Old April 25th 2017, 16:05
Thanks Petevw
There's your limit I think.
Old December 17th 2017, 01:06
rioprelude rioprelude is offline
Hey Steve, how is your build going?
Old December 19th 2017, 05:00
Its good to be back, thanks to everyone that worked to get the site going again. I will need to fix my photos up that are hosted on Photobucket
A lots been happening with my bug. I had the car back on the road for a few days and bent a rod, my fault, I got a bit carried away and drove it through a missfire.
So its a fully forged strocker motor, 2.5 crank, Argo rods, Manley pistons etc 2142cc it made 305 kW on 29 psi, Tomei cams are now responding to tuning thanks to a new ECU, it also made 200kW at just 4,500 rpm, the torque is amazing.
I also fitted an Accusump and Radium fuel rails and dampener.
Ive loaded a dyno photo, not sire if it will work, Red blue green 3 boost settings. Pink is old setup
Old December 19th 2017, 05:02
PS, photo loaded OK so I will load some more and update old posts
Old December 19th 2017, 06:30
A few extra photos, Accusump
Old December 19th 2017, 06:34
Radium fuel rails and fuel dampener
Old December 19th 2017, 07:01
After my Beetle crashed into my sons Beetle we did an update on it, Aero kit the same as mine, he borrowed my wheels for a while. Were building Oxy boxer for it, 82x94, Street elims, 48 IDFs dry sump etc
