Old September 14th 2018, 03:30
I can't remember the exact name of the short shift kit I got for it many years ago, but it sounded like J-West or s/th. At Pelican parts in the US you can find it in their webshop. Its the only one at reasonable price afaik.
6100 over the line and 7300 limit seems like there is room for a much, much higher speed
Old December 16th 2018, 23:33
I had my car corner weighted and 4 wheel aligned few months ago, it was all over the place, it took them a few hours to do it, they asked me when adjusting height if I wanted to higher or lower, I said lower. I think it looks better.
Old January 16th 2019, 00:45
I've been having fun driving the Beetle around, I'm going to do Powercruise at Sydney Motorsport Park next month, after that I will pull the motor out and get a new clutch made.
I also just bought a Tial .82 rear housing, I'm getting GCG a local turbo place to do some magic on the cool side of the turbo and then I will go looking for some more kWs.
The Aussie dollar has really dropped so I bought the housing for a pretty good price from a local seller for $585 Aud
The smaller .63 rear housing was restricting it a bit.
Old January 21st 2019, 14:14
Looks awesome!
Old August 30th 2019, 23:11
I took my bug out to do a Supersprint at Eastern Creek before I removed the motor to do the clutch, I took it easy first run out only to find that my tyre gobbled up my mudguard air intake and that the motor started leaking oil from the right cam cover, I stopped running then and took it home as I didn't want drop oil on the track. I had a good look at the track to find the leak with no luck, I've since found that it was a leaky inlet cam actuator.
So I pulled the motor and found a rather scorched clutch plate. I sent the whole clutch and flywheel assembly to a very good place in Queensland about 1000 ks away. My son is into drifting and NPC do a lot of the drift car clutches. They found that the Kenndy pressure plate and flywheel just needed a grind but I have gone to one of their cushion button clutch plates.
So the motor is out now, I'm going to send the car away to have a 1/2 cage fitted that will tie into rear part of the chassis.
I asked for advice from a water cooled VW tuner when I made my air intake in the right mudguard about what sort of enclosed air filter to use. So I bought an Italian made BMC Oval Trumpet air filter, the VW tuner told me he was using these on 400 hp water cooled VWs.
You can see the BMC air filter in the top view of my engine
I sent an email to BMC asking what would be the upper limit of this air filter.
Their reply,
"It is difficult to answer. 307 kW is about 415 hp.
In the past we tested the OTAs on engines having the above power, but due to the huge quantity of air they needed, they were insufficient to power any engine.
The best result we achieved is around 300 hp = 180 rwKw.
Please take note that also other factors must be considered, such as for instance the load loss consequent to the installation.
Just to sum up, it is not only a matter of empirical power.
We eventually recommend the filer with PN ACCDA100-220-01."
My tuner was worried that he couldn't account for the air flow into the inlet at high speed so I'm pretty sure I'm going to use a Blitz Carbon Core but this time I will only have the air from my mudguard intake blowing on the filter inlet not physically connected as I did with the BMC unit .
Old October 18th 2019, 21:42
As anybody knows who has added more contemporary parts to an old VW you know that you soon run out of places to fit things.
I'm running an in tank Walbro 460, I did suffer some fuel surge at the VW Nationals Supersprint so I'm now fitting a Taarks surge tank with another Walbro 460 inside, the Walbro pump in the fuel tank will now feed the Taarks surge tank.
One Walbro 460 is good for about 560 kW, if I need more fuel supply I can simply fit another pump inside the surge tank. Im aiming for 400 rwkW at the wheels so one 460 should be enough.
Old October 20th 2019, 03:24
Hi Wally
I'm on E85. My motor was built by Deschele Performance in Western Sydney to make 400 awdkW (ie Subaru awd). I made 305 rwkW on 29 PSI. I'm hoping that going from a .63 to a .82 and a better air intake will allow me make close to 400 rwkW, if not time for a new turbo.
The front pump will have little load and the pump in the surge tank has a 0 gauge battery cable going past it so I will run high power consumption relays on both pumps, I've moved my battery into the trunk/boot area. The surge tank is now in the stock battery location.
The motor is still out of the car, some of my sons drift friends build high end roll cage for all forms of motor sport and we are designing a cage for my car to comply with IHRA rules. Even though 1/4 mile racing is not my main focus they are the strictest rules of any motor sport that I wish to compete in.
I will be allowed to run down to 10.5 with a 1/2 cage with side intrusion bars, any quicker and I will need to go 6 point cage. The main issue is that the main hoop has to give me 6 inches of helmet clearance while still being perpendicular to the chassis, the base for the hoop leg is going to have to be a long way back in the car. I'e run a 12.1 with 220 rwkW. We are also tying the cage into the rear chassis area.
Old February 11th 2020, 03:56
Long time no post. Been playing with my new Jap car, a JZX110 while waiting get my bug back on the road.
My bug has been off the road for a while, first for a new clutch and then I decided to have a roll cage fitted.
Some of my sons friends have started a fabrication shop called Ministry of Fabrication, I had to wait a while for them to fit me into their schedule. Its a full cage, removable taxi bar, removable front legs and intrusion bars and being tied into the rear chassis forks. Its being done IHRA regulations, it will allow me to do down to a 8 second pass, I will be happy to get into the 10s but I thought I should all out just in case
Old February 11th 2020, 09:04
Flintstones's Avatar
Flintstones Flintstones is offline
It's getting busy in there!
Old February 11th 2020, 21:37
sure is, I can hang the washing out in the car
Old February 28th 2020, 04:05
Getting the car back this weekend, then I have to put it back together. Really happy with the cage, getting it signed off by the IHRA tech guy soon. It will be certified to do a 8.00 pass, I will be happy to get into the tens.
Old March 1st 2020, 15:37
Looks strong indeed, good call to have this done!
Does it feel stiffer as well?
Old March 1st 2020, 23:16
Hi Wally
I haven't driven it yet, getting inspected tomorrow night by the IHRA tech guy then I can put it back together, motor is out of the car so that they could work around tying the chassis to rear of the car
Old March 3rd 2020, 21:17
Just had the car inspected by the IHRA guy, passed with flying colours, he was very impressed with how it was done, needs another inspection with the car ready to race with all safety gear etc then it is able to go down to a 8.00. pass. I will be happy to get into the 10s.
When I first thought about having a cage fitted I wanted to stiffen up the chassis. When built the car I had to make new top shock mounts so that I could lay the shocks over to clear the axles as the motor and trans are 100 mm forward. Ministry of Fabrication tied the cage into the extended shock mounts.
Old March 3rd 2020, 21:36
I was running some Toyo R888R on the street, 225 40 x 18 & 245 40 x 18, great tyre but a little stiff. Iv'e now fitted these tyres to some hollow spoke twist wheels for track days.
So now I'm going to run some Nitto Invos in 225 40 x 18 and 265 35 x 18.
I also had the wheels repainted while they were off the car, same colour
Currently Active Users Viewing This Thread: 4 (0 members and 4 guests)
