Old May 7th 2016, 14:17
fahrvergnugen fahrvergnugen is offline
Originally Posted by piledriver View Post
I almost went there awhile back, and may still.
Might as well install some real height adjusters in the torsion while at it >;-)
Here was my inspiration for adjustable inner pivots
http://tr6.danielsonfamily.org/TrailingArmKit.htm
Would need some redesign for our use, but the large dia inner "crush tube" in the bushings should make it pretty sturdy.
Anyone offhand know the proper shock length with aluminum arms in a T1 or T3 with std upper mounts?
(T3s upper mounts are double shear BTW)
Good find. Check these adjusters of our beemer friends.
https://www.iemotorsport.com/bmw/E30...bkit-lock.html
Guy i know used these on his early bay and they work great.
If some is good and more is better, then too much should be just about right!
Old May 7th 2016, 14:21
Zero camber @ the lowest position. now i have to check the camber when it's a bit higher.
Old May 8th 2016, 02:34
piledriver piledriver is offline
Another option posted that came up when I was looking at taking the sawzall/welder at it similarly was that Marco Mansi sells T1-inner mount eccentric bolts.
His website seems to be down at the moment (worked recently) , but here's a thread where he first posted them AFAICT, with pics if you scroll down...
Cell phone cameras have come a long way since 2007
These have been around awhile so you may have seen them, just crossing the "i"s and dotting all the "t"s.
Putting my 86 944T arms on next week.
Played with ludicrous sized front brakes today.
Figured out a cheap DIY mostly bolt on combo for Wilwood Dynalites w/vented rotors for T3s.
(works better with early spindles, not bad calipers with the bridge bolt mod)
Also found how I'll probably install the Superlites, a little welding needed.
I cant shrink the pics to 85K, not happening. That's worse than even the STF with its odd image geometry size limits and related issues.
Will link if interested, need to post over there anyway on project.
Old May 8th 2016, 14:50
Hi Piledriver,
Please start a topic so that we can see your project, sounds interesting.
I have the Marco Mansi adjusters but I am not really happy with them. not enough adjustment for my setup and I had to modify them to make them fit.
Old July 6th 2016, 12:19
Rearsuspension version 3.0 is almost ready, only need to receive the new toe in / toe out adjuster plates and mount them. also relocated the gearbox and made new mountings.
Old November 15th 2016, 17:29
Done some small things, but has to be done.
*Made a stronger adjustable bracket for the rear suspension and bought 10,9 bolts and nuts to mount them.
*Changed the Porsche 914 hubs from 4 to 6 bolts.
*Made a bracket for the new throttle cable.
*Made a throttle cable mount to the throttle pedal.
*Pressure test the rear brakes (fail :-( )
Old November 15th 2016, 22:25
H2OSB H2OSB is offline
I'm sorry if you've already stated this, but what steering rack is that out of? Nice work!
johnL (aka H2OSB)
Old November 16th 2016, 02:26
Hi John,
Thanks, the steeringrack is from a rhd Hyundai
Old November 27th 2016, 08:21
Made 2 driveshafts out of 4 VW Golf shafts.
Yesterday I mounted the T1 and T2 CV's and fitted them on the car.
Paul.
Old November 27th 2016, 16:40
Not sure why I hadn't read through this entire thread before but you've done amazing work!
H2OSB
johnL (aka H2OSB)
Old November 28th 2016, 17:04
H2OSB
Thanx.
Old December 4th 2016, 14:05
The chassis is ready (so far) so the body is on again.
Old December 24th 2016, 11:17
The front is nearly ready.
fitting the Porsche suspension
And it's on 4 wheels again.
Old December 24th 2016, 18:15
Flintstones's Avatar
Flintstones Flintstones is offline
The progress is looking good!
Old December 28th 2016, 17:04
Thanks.
