#391
Nice meaty tyres! And i like the solution you did on the rims of the cookies.
VW Super Beetle 1303 1973 Kolibri Grün Metallic |
#392
Thanks, it wasn't cheap but neither was buying 3 piece rims so that I could get the correct offset.
I did feel a little guilty having genuine Porsche wheels modified, I'm over it now
#393
Here in the Netherlands a lot of genuine Porsche rims are massacred for the auto cross (widened and narrowed). And after some beating they will end up in the trashcan.....
So don't feel guilty
#394
I took my Beetle out to Powerplay on the weekend, fitted up the new M&H for a few heat cycles (skids)
#395
Finally got a dry Wednesday night so I took my bug out to the drags. Getting used to launching and shifting gears again, I need some improvement. I was getting some wheel hop which I'm sure caused me to break a drive shaft. I need to tie the motor and trans down a bit better Its a custom drive shaft, modified 944 with a 930 CV flange welded on. The guy who made them cant do anything for 5 weeks so I'm trying to organise getting one done so that I can run at the VW Nationals Supersprint. If anybody knows of someone that could help with welding and machining let me know. Best ET was 11.803 and best MPH 124.29
#396
Ouch! Sorry you ran into issues!
If I could just get paid for my sleepless nights.... 1960 VW Bug UBRDUB Walkaround 1st Drag Run Dyno Run Oval Ragster-'57 Rag/'04 Boxster S |
#397
oofffff, done that before on a trans output shaft.
'72 super '65 bus '52 split |
#398
I had some new billet 944 stub axles made in in EN26. Im fitting some Subaru Group N engine mounts when they turn up from Japan and Ive fitted Superpro urethane bushes to the front engine mount cross member. Hopefully this might help my wheel hop issue
#399
That are some nice pieces sir!
#400
Last year I fitted some twin Spal fans to my 944 radiator. I had to cut the housing a bit to fit them.
I've just fitted dual thermo fan switch in radiator as used in Alfas. It has the same M22 thread that's in my radiator. The only one I could find with a suitable temperature range was made by Tridion with Operating Temp: 92°C - 87°C & 97°C - 92°C
| Currently Active Users Viewing This Thread: 17 (0 members and 17 guests) | |
