Old February 2nd 2005, 21:12
justdubbin's Avatar
Originally Posted by NO_H2O
ANypne who can fab. a rollcage like this can fab. a new filler neck :agree:
I know what you mean but I was thinking about the pump nozzels with the benzen (sp?) extractors(I think that's what there called), they have to fit all the way in the filler neck before dispensing the fuel.
Rob.
Old February 3rd 2005, 07:17
Racelook's Avatar
Racelook Racelook is offline
Originally Posted by justdubbin
Is it the angle that this picture is taken because it looks as though you might not be able to connect the fuel filler?
I hope I'm wrong
So as you can see that the bracket is not ready welded on the plate. And also there is a little bend in the tube so that it clears the tankinlet and that it don't stuck to the sidepanel (the sidepanel goes some to the innerside as you go to the front).
Yep you have to think of everything, but that the nice thing of it.
Wiebrand
B-Extreme B-Tuning.....
Old February 3rd 2005, 17:06
coxy-ben's Avatar
coxy-ben coxy-ben is offline
I like this !!!
good job !!!
Spa, bug show 2005 ??? Could I see it finished ??
2FAST4U
Old February 3rd 2005, 18:12
Racelook's Avatar
Too Much Smilies!!!!!!!!!!!!!!!!!
HAHAHAHAHA
I don't think so .. I wil be there but not with my car
Wiebrand.. You're also on every forum mate
Old February 4th 2005, 14:18
coxy-ben's Avatar
Originally Posted by Racelook
HAHAHAHAHA
ok wiebrand.....
I won't see it at the bugshow.....
2FAST4U
Old February 13th 2005, 08:16
coxy-ben's Avatar
what's news ??
2FAST4U
Old February 13th 2005, 18:56
Racelook's Avatar
GHE GHE.. curious Ben??
Today (after I've laid 4 days in bed because I was sick) finally there's done quite what..
But I've maked no pictures yet.. Sooooooo you have to wait till tomorrow
Wiebrand
Old February 14th 2005, 17:46
Racelook's Avatar
So here's finally my update!!
At first we mate two brackets, that we welded to the boxes on the rearwheelarces.
At first the leftside:
This is the right one
http://www.keversite.nl/fotoalbum/fo...2005202124.jpg
This gives the next total picture when the tubes is maked on mate.Looks nice if I may say by myself.
Old February 14th 2005, 17:47
Racelook's Avatar
Second we have made brackets that we one one side have welded on the strutbraceplates.
And here also an total picture ofit seen from the trunk.
Old February 14th 2005, 17:48
Racelook's Avatar
Thumbs down
On the tank you also see the tube for the right side. Also are the brackets for this tube ready to be welded on the cage and on the strutbraceplate. So that one will be in next week.
I hope you liked it!!!
Grt Wiebrand
Old February 14th 2005, 17:49
Racelook's Avatar
p.s. why can I NOT make longer post at one time!!!! This only causes spacetrubble.. but yeah....
P.S. I hate TOOOOOOOO much tags/smiles in your post message...pffffff
Old February 14th 2005, 18:14
coxy-ben's Avatar
yeah baby !!!!
nice job !!
do you know the weight of it ???
Benoît
2FAST4U
Old February 28th 2005, 18:44
Racelook's Avatar
Ben
It weights 3,09 kilogram the meter.
Wiebrand
Old February 28th 2005, 18:57
Racelook's Avatar
SO BOYS AND GIRLS.
It's about time for another update. And I must say it's getting ready quite nice.
At first we had made the tube on the right side that goes to the strutbrace http://www.keversite.nl/fotoalbum/fo...2005223535.jpg
There must be made another 2 tubes for the strutbrace to the cage and then is the hole front side ready!! Here an totalpic till now.
A picie form about
http://www.keversite.nl/fotoalbum/fo...2005223714.jpg
For the tubes from the cage to the chassistunnel there is welded an bracket at the cage. Also the tubes are made on the right size and are welded off. And that gifs the next pic.
The totalpicture from the front
http://www.keversite.nl/fotoalbum/fo...2005224025.jpg
The totalpicture from the back
After that we made an tube on the right size for between the cage and the brackets on the rear wheelarces.
Detailpic of the welding... Looks damn nice if you ask me..
http://www.keversite.nl/fotoalbum/fo...2005224210.jpg
Old February 28th 2005, 18:58
Racelook's Avatar
And also the next tube is made on the right size. The cost verry much time ; grinding, fitting, grinding, fitting, grinding, etc.. But after all it fits damn nice.
Detail pic from above http://www.keversite.nl/fotoalbum/fo...2005224350.jpg
Detailpic from under
http://www.keversite.nl/fotoalbum/fo...2005224426.jpg
But yeah if it goes on the leftside it also has to come on the rightside. http://www.keversite.nl/fotoalbum/fo...2005224459.jpg
And also tonight I 've worked on the cage and 1 tube of the cross of the cage is also ready to be welded in.
I hope you enjoyed it.
Greetings Wiebrand
