Old October 16th 2005, 08:51
nbturbo's Avatar
nbturbo nbturbo is offline
Oval GL coming together
Finally,after about 4 years it's starting to happen.I am running a 2.7lt Type 4 with 48mm Webers (but will be injected B4 it goes on the road) Made a stainless muffler similar to an original with 2x65mm tail pipes out of the original holes.Have IRS'd the pan and modified it to fit an auto trans from a Type 3. Running weld in adjusters up front and 4 wheel discs with 17X7 up front and 17X8 at the back.May be able to fit 18X9's on the back yet.Will see after the rear guards are on. I am using Aero Guards all round ( locally made using the original 6 volt headlights,but use the big tailights)I wanted to fit a Superbug engine cover with the 4 slots, so the engine could get all the air possible,and needed more room for the exhaust,so welded in a late fuel injected rear panel.I have had all new glass for it(except the Oval)with all the side glass made with the tint in the glass and a laminated/tinted front screen.The headlining has been done in an original looking fabric,but is grey in colour.The front buckets came from a Mitsubishi Starion and I am having them and the rear done in black leather.I am doing this one to be a sort of twin to my Turbo NB.Same colours used thru out with seats/trim etc.
Old October 16th 2005, 09:04
nbturbo's Avatar
Some more info
That speedo is an original European KPH,which I have had modified with a MPH gear set and recalibrated and fitted the small MPH sticker.Wanted to keep the early look speedo,and also have a fuel guage.I cut the sunroof from a rusted out 66 and after 12 months,finally got a panel beater to help me graft it in.It works like a new one.With the pan,I had to shift the horns out 50mm each side to get the auto to fit and still be strong enough.I welded gussets inside the horns,but am making a Kafer type brace as well to tie in to the shock towers.
Old October 16th 2005, 10:30
Soul Soul is offline
Nice work! I like the speedometer mod, I was going to do something like that with the speedo in my oval.
Old October 16th 2005, 10:36
Rob's Avatar
Rob Rob is offline
Wow, very nice.
I'm seriously impressed with all the fabrication you did, looks very nice.
If you don't mind me asking, why did you go with an automatic ?
Rob.
Old October 16th 2005, 11:32
Thats looking good...what kind of exhaust is that?
Old October 16th 2005, 13:17
Massive Type IV's Avatar
Ask Zen about the time he tried to let "looks" cool his engine.......
Jake Raby
Old October 17th 2005, 02:05
nbturbo's Avatar
As I said-wanted to make something similar to the NB-which is an 03 turbo with auto and sunroof and they are nearly 50 years apart.When I started this I had a list of must haves-big horsepower motor,auto trans and air conditioning.The air is not going to happen because of the fan set up,but I was determined to go auto.When I bought this engine,it had been raced hard in a single seat buggy with a FAT shroud and a big external cooler.(now running all Sharpbuilt stuff and machined the breather tower)I stripped the thing right down,and apart from some rough clearancing inside the case,it was in very good condition.The heads had 48 and 38 valves and only needed a freshen up-everything was like new.I got another case and clearanced it properly,had everything balanced and crack tested and changed the ****ty wild cam and put in new rings and bearings.Had to get a 210 flywheel because it had a 228 with a pressure plate that only Arnold could operate.I am using the original oil cooler as well as a sandwich plate to an extra fan assist cooler.I made all the exhaust using the stubs from the original FAT buggy pipes,and bought some bends and made the engine pipes.I had some flanges profile cut so I could use original Type4 gaskets.The muffler and pipes are from stainless.I had 2 half cicles rolled with 10mm lips to give me a 61/2 inch tube when welded together.Run 4 perforated pipes inside to ech opposite end and run the tailpipes out thru the original cutouts.It's still a little loud,so will make the tailpipes into mufflers like the originals.I had to do a cutout to clear the crank pulley and welded in the bung for the O2 sensor.The muffler hung a little low when finished and looked like a set of dog's nuts hanging out in shiny stainless-so had the whole lot ceramic coated in matt black-not so obvious now. It will only get an occasional Sunday run,so should be up for all I can throw at it.I had this 2700 badge laser cut in aluminium and the style is as close as they could do to copy the original VW 1300 script.I had to hand finish the edges,then had the 3 of them coated in 24ct gold for something a little different.
Old December 24th 2005, 08:03
tommi_nylund tommi_nylund is offline
Oval with elephant foot rear lights, latest rear apron and latest engine lid....... Oh god....
Even though your car is oval with 'different' style (and everything you can´t see outside is also made with extreme care) and no matter how much I´ve look those pictures I still can´t like it.
But I think here are people who love your car even I dont! :agree:
Old December 25th 2005, 03:01
I like it. A lot. It pulls (or is it pools?) a lot of seemingly conflicting styles together very nicely.
Old December 25th 2005, 05:05
nbturbo's Avatar
Fitted the fronts as well-will wire everything up-then lift it onto the pan.
Old January 12th 2006, 01:34
nbturbo's Avatar
Put the body back on the pan yesterday.Got away with using a felt sling thru the door openings and and it balanced really good.With all the cutting and welding I did to fit the auto,and only using an old body section for a guide,I had the rear of the motor 15mm too low and 6mm offset to the right.Can easily modify the mounts I made that bolt up to bellhousing to correct this.I am really happy with how it all fits and looks.
Old January 12th 2006, 04:05
Originally Posted by nbturbo
Put the body back on the pan yesterday...I am really happy with how it all fits and looks.
Gee, I guess so! Fantastic! :agree:
