Old December 31st 2009, 15:50
Wow! You did get alot done! The POR-15 stuff is great! It's coming along really good. Keep it up!
Old January 2nd 2010, 16:04
Rob's Avatar
Rob Rob is offline
Awesome work Sandeep.
So you need a special primer over the POR15 before you can cover it with the Tremclad ?
Do you have a heated garage or does the POR15 cure in low temps as well ?
Rob.
Old January 2nd 2010, 16:34
big daddy's Avatar
big daddy big daddy is offline
Looks good Sandeep, your really commited you did all that work on your own? Will ET of finish, is by summer?
Good Job
Big Daddy/ VW EGO
Lets Gooooo
Old January 2nd 2010, 18:43
You need a primer to bond to the POR 15 called Tie Coat primer made by POR 15. Other paints then bond to the tie coat primer.
I have a BBQ propane tank with a heater attachment, so the area around the pan stays at about 15C
All work has been done by myself. Now I just have to bolt the whole thing together
Summer 2010 is the goal.
Old January 2nd 2010, 19:50
fast Ed's Avatar
fast Ed fast Ed is offline
Nice work Sandeep, props on keeping the project going. My attention span is way too short for long-term ones like that, I need to be able to drive it!!
Remember I'm not far away from you, if you find yourself in a situation where you need an extra set of hands while working on it.
Looking forward to seeing the car and getting a ride in it this summer.
cheers
Ed N.
67 Beetle Sedan
95 Taurus SHO
89 Mustang GT
Old January 4th 2010, 15:12
CLKWRK's Avatar
CLKWRK CLKWRK is offline
Looks really good Sandeep! Cant wait to see this monster back on the road.
I am stuck at the "wait for bodyshop" stage, my goal is also summer 2010
GL ghia restoration:
Old January 4th 2010, 19:11
Good stuff. You will love the Tilton pedals. I have installed a set in the Herbie X project. There are some problem ares you will have to work around but they will fit and work. I want to put a set in my car but have not had the time or funds to do it.
Old January 10th 2010, 02:54
Another Saturday, some more progress
And a Christmas present from Santa
Old January 10th 2010, 08:22
Xellex's Avatar
Xellex Xellex is offline
Sandeep, what brand are the throttle bodies? And how do the air filters get mounted on those?
Oh, and nice project going on there, I love everything about it
www.vw1303s.com
Old January 10th 2010, 10:47
The TB's are tapered 50mm / 45mm extrudabody.com units that flow more than 48mm TWM's. All the information is on their website.
Old January 10th 2010, 15:29
gonebuggy's Avatar
Looking fabulous Sandeep! I have faith it will be done this summer!
That gearbox is HUGE!
1970 Bug
2110cc. ???Whp, ???Ft/Lbs
Old January 11th 2010, 03:24
She's gunna be pretty!
Old March 15th 2010, 19:49
Some more progress on another major project on the pan ... the tilton pedals
What a pain in the A$$ to get these to fit properly. I had to "massage" the drivers side heater channel and make a base plate to bolt the pedals do as the pan material is thin.
I like the fit, now just need to run the brake / clutch slave lines.
I've got some proper couplers made up, don't mind the welded nuts ...
Old March 15th 2010, 19:55
Another package arrived from the good folks at Aircooled Heaven.
Twin plug turbo heads, 10mm spark plugs top and bottom, 42 x 38 valves, machined for V2 98mm Nickes. The exhaust flows 150 cfm @ .500" with a full valve guide
Almost ready to start assembling the engine
Old March 15th 2010, 21:08
chug_A_bug's Avatar
very nice work Sandeep, LOVE the TB's
and the pedal set up and those HEADS WOW!
can't wait to See it out this summer
74 Std. GL
08 Vw rabbit
18 WR250R
07 Chevy 3500 Dually
