Old March 2nd 2005, 16:22
Racelook's Avatar
Racelook Racelook is offline
So yesterdayevening I had some time, so I have worked on my cage.
The first piece of the cross in the cage is ready and is till thursday tacked in.
Under
http://www.keversite.nl/fotoalbum/fo...2005211031.jpg
Above
http://www.keversite.nl/fotoalbum/fo...2005211057.jpg
The other half of the cross is made almost on the right size. Here a little pre-look at it.
Greetings Wiebrand
B-Extreme B-Tuning.....
Old March 17th 2005, 19:43
Racelook's Avatar
So finally I had some time to get on with the cage again.
At first an brither pic of the cross in the cage (not totally ready yet).
http://www.keversite.nl/fotoalbum/fo...2005230215.jpg
And anbetter pic of the welding on the back wheelarces.
http://www.keversite.nl/fotoalbum/fo...2005230528.jpg
At first I had maked two other holes in the dashboardplate so that the tubes from the struts can go to the cage.
Pic from the inside (driversside).
Pic from trunk (driverside)
http://www.keversite.nl/fotoalbum/fo...2005230812.jpg
Also we had bendend 2 tubes that will go in front of the doors from the a- to the b-pillar.
After that we welded brackets on the tube at the a-pillar. So that the tube from the strut can be mounted to the cage.
Driversside
http://www.keversite.nl/fotoalbum/fo...2005231044.jpg
Passengerside
http://www.keversite.nl/fotoalbum/fo...2005231132.jpg
Racelook's Avatar
There's also an bracket welded tot the long tube (from the strut tot the cage) so that the short tube can be mounted from the strut to the cage.
An detailpic of the bracket welded on the long tube.
http://www.keversite.nl/fotoalbum/fo...2005231344.jpg
And FINALLY the front of the cage is READY. It was about time!!!
Seen from the trunk.
From the interior.
See ya next time
Wiebrand
Old March 17th 2005, 22:16
It looks solid there man...nice job! :agree:
VolkSport Kfer Gruppe
www.VolkSport.net
Old March 18th 2005, 01:45
coxy-ben's Avatar
coxy-ben coxy-ben is offline
Thumbs up
good job !!!!!!!!!!!!!!!!!!!!
:agree:
you don't want to come in France for one or two weeks ???
I have a small job for you !!!......
2FAST4U
Old March 18th 2005, 01:47
volksdragon's Avatar
wow
Old April 7th 2005, 17:49
Racelook's Avatar
WAKE UP, WAKE UP:
It's time for another update.
Last week I've begun starting to bend the last tubes for the cage.
http://www.keversite.nl/fotoalbum/fo...2005001341.jpg
And that gives this final result.
It need to be shortend on the right size and then also this one can be welded in.
Also is the cross welded in.
http://www.keversite.nl/fotoalbum/fo...2005001514.jpg
And that gives this nice picture (if I may say).
Here some detailpics of the welding
http://www.keversite.nl/fotoalbum/fo...2005001624.jpg
http://www.keversite.nl/fotoalbum/fo...2005001729.jpg
Grt. Wiebrand
Old April 7th 2005, 17:54
Racelook's Avatar
Yes, yes 2 updates at one tim .
The second-last tubes are welded in last sunday. It are the two tubes that goes along the doors.
Picture from above. It's good to see that the tubes clears the door all the way.
Picture of the to welded tubes.
http://www.keversite.nl/fotoalbum/fo...2005231032.jpg
http://www.keversite.nl/fotoalbum/fo...2005231158.jpg
Old April 7th 2005, 17:56
Racelook's Avatar
Detail pic of one of the weldings in the cage.
http://www.keversite.nl/fotoalbum/fo...2005231301.jpg
And at least some total pics of the cage so far it is now. It must said that 3 tubes are not yet in on this picture and that 1 tubes still needs to be welded in.
http://www.keversite.nl/fotoalbum/fo...2005232307.jpg
Mondayevening also 2 tubes mate on the right size.
http://www.keversite.nl/fotoalbum/fo...2005232427.jpg
1 is ready and fits really nice.
Grt Wiebrand
Old April 7th 2005, 18:33
MattKab's Avatar
MattKab MattKab is offline
Thumbs up
:agree: :agree:
Old April 22nd 2005, 08:43
zeroaxe zeroaxe is offline
How much experience do yo uhave with Fastbacks? I got here waiting for you....
Old May 5th 2005, 09:39
coxy-ben's Avatar
a new update wiebrand ????
2FAST4U
Old May 5th 2005, 11:13
Racelook's Avatar
Mwhaa Ben.
There's only an verry little update of the cage. The "fixingtubes" are widered (uitgedraaid in het nederlands) for the right diameter and are drilled so that the several pieces of the cage can be bolted together at the end.
The next update will be over a couple of weeks I'm afraid because I'm now verry busy with the chassis (new fuellines 2*12mm and new brakelines). When I've fixed that I will paint the chassis and the cage at the same time.
Wiebrand
Old May 5th 2005, 12:32
coxy-ben's Avatar
ok wiebrand ! :agree:
good job !!
2FAST4U
Old May 5th 2005, 17:08
tom'72's Avatar
tom'72 tom'72 is offline
If I'm not mistaken the correct therm for "widered" is machined off (als ik me me goed kan herinneren van de Engelse les vroeger tenminste)
