Old December 23rd 2009, 03:27
Humble's Avatar
Humble Humble is offline
Good luck with the thumb, hopefully it heals up okay
Old December 27th 2009, 12:52
speedy's Avatar
speedy speedy is offline
hey Dave , nice to see you are still busy, the car is looking very nice , I am going to start on mine (dry sump ) in the new year
Jonathan
woop woop
67 2276 turbo
64 ghia 1776
zx7rr
Old December 28th 2009, 11:19
Last follow up was today and I have a green light to start back. Might get back to it this afternoon.
Jonathan, I hope you dry sump project goes well. Did you get your new ECU sorted out?
Old December 29th 2009, 09:07
That's good news. Glad to hear it.
(2004-2008): 1971 1302 w/2056
Old January 4th 2010, 15:15
kuleinc's Avatar
kuleinc kuleinc is offline
Any news from the holidays?
Everyone told me its not a good idea to daily drive an aircooled bug. I agree, if the engine has a distributor and you use cheap engine parts... OR you have an early car without the decklid vents or you neglect to add an oil cooler with fan...
Old January 4th 2010, 18:55
I need some more shims for the pushrod tubes. When the engine is warmed up, the "O"rings on the outboard ends start to show and oil starts to seep from them. I ordered another set of .132" shims but they are a bit too much so I ordered what I hope will be a set of .040" shims that should do the job. I have over a hour of run time on it and have pulled the lifters after each 30 minutes and they look good. After I get the shims in, I will up my idle jets and get that dialed in and get another hour of run time done before I stab it in the car.
Old January 4th 2010, 21:33
I call shotgun!!!
Old January 4th 2010, 22:38
your on.
Old January 5th 2010, 20:51
Cool deal!
Old January 5th 2010, 21:18
I did not get PR tube shims in time for this weekend so I did the disc brake upgrade to my son's 73 GL. Also di the front sway bar upgrade. Got everything finished and was putting my tools in my car and had Ryan throw the wheels on so he could try out his new stuff. The wheels hit the calipers so we were done. They are the early wide lip style Riviera's that you see on a few 914's. I guess they are earlier than I thought. I do have a set of 8 spokes that he can run untill he finds a set of 2L Fuchs.
Anyway, I got the PR tube shims in the mail today. My next set of off days should bring some progress.
Old January 5th 2010, 23:18
To bad the Rivieras don't fit on you son's bug now (I hate eight spokes).
Glad you got the shims already...not long now.
Old January 15th 2010, 17:25
Got a chance to get some more run time on it today. I will inspect the lifters one more time and get some more 93 octane fuel and do a final tune on it, fit the sealing tin and pull it off the test stand.
Old January 15th 2010, 19:26
I moved this to the build section. Thought I would throw in a pic of my transaxle. Its from Rancho and has all the tricks. 3.88 R/P and an 0.82 4th.
Old January 15th 2010, 23:13
stab that thing in there, and get it on the road!
Old January 19th 2010, 23:43
Good for you, Dave.
