Old January 30th 2003, 01:18
Is there an advantage to front steering? I read in one of the suspension design books that front steer has some advantage when hitting a bump during cornering. It causes understeer for a split second rather than oversteer and makes the corner seem more comfortable. I could make the steering rack I have work as a front steer rack, but I had planned on rear steer. I had already thought about switching the steering arms, but there will be an increase in length if the same bolt holes are used, slowing down the turning rate, I presume. I will have new front steer arms built to have the correct length IF front steer is better, because it will involve getting a new front steer rack or making the other work backwards. If not, I think I'll stick with new rear steer arms moving the joint up high. Any thoughts you have would be greatly appreciated, as you have much more experience in this area than I.
Old January 31st 2003, 18:36
Ross Morrison Ross Morrison is offline
Jason,
I was just throwing ideas around.
I have never read about those benefits of front steer.
Personally, I like the idea of the rack being behind any uprights, so as to offer some kind of protection in a smallish shunt. At least you could drive it home!
I would be interested to see the new arms you get made.
Cheers,Ross.
Old March 7th 2003, 23:48
Lightbulb Update
www.geocities.com/volkdent/
Click on Conversion
Old March 31st 2003, 21:17
Shadowbug's Avatar
I have to say, when I first read your idea of upgrading the front suspension I was intrigued but not interested, but I think I may just consider this swap over the next winter.
I currently have a IRS Balljoint pan, and may even upgrade the rear suspension as well If I can get it all to fit under the stock fenders ( I'm not opposed to cutting the body, Though I'd rather not)
and I'd even like to use the stock spindles
Volkdent
what is the rear suspension pictured on your site out of?
Old April 1st 2003, 02:15
I'm halting on the 928 spindle, as it is causing me a little extra stress right now, but I'll come back to it later. I'm working with the stock BJ spindle right now, and maybe a lowered CB one later.
The rear end you are asking about is a 996 Turbo I believe.
Old April 1st 2003, 13:13
Shadowbug's Avatar
I may just fab up some equal length A arms using my balljoint spindles, just to see how feasible it is
I've been considering pulling my pan off again and doing a bunch of work to it, but I may just grab another pan (I have a buddy with a VW wrecking yard, I can get a pan for nothing)
make all my mods to it and if it doesn't work out, well I still have my other pan.
Old June 19th 2003, 20:08
Back At It
I finally recieved the Karmann Ghia front spindles with rotors drilled for Porsche. This should be an easier starting point. My suspension mentor, Bob Frostick-Stevenson, is back home too, so progress will hopefully continue now. I guess this is why my VW had been my hobby since I was 15! I'm 31 now!
Old November 20th 2003, 19:52
Daggis Daggis is offline
How is this coming along?
Old November 21st 2003, 22:56
It
Well, there came a certain someone in my life and she's a little more fun than ball joints! Speaking of which though, I finally just found the ones that will work. They are are from a Ford Granada and fit the KG spindle well. So no it's just a matter of taking the time to get all the measurements again then send the data off to Bob.
Old December 2nd 2003, 20:18
Shadowbug's Avatar
hmmm ford granada
been mulling it over, I've decided that the best way to develop a suspension is to just build one, or a couple.
I have access to conduit for cheap so I'm going to build a scale suspension and see how the geometry plays out. if I come up with a setup that I like, I'll go to full size, tack it all together and have a structural welder do the finish welding.
a few pics of my project
Old December 9th 2003, 19:30
Hey shadowbug, don't use equal length arms as you wont get much camber change in roll.
If you shorten the top arm it will work better.
Old December 10th 2003, 00:46
Shadowbug's Avatar
The idea is to use unequal length a arms, long as posstible on the bottom.
I'm looking into doing an AWD system so I'll need to use spindles from a front wheel drive vehicle (have been thinking VW golf)
Old December 15th 2003, 21:08
miller's Avatar
miller miller is offline
Hey what are you gonna use for the AWD system? Are you gonna use a subaru setup? if not what system/
Old December 16th 2003, 23:00
Shadowbug's Avatar
decided that it didn't make sence to build an entirely new chassis when the one I had was more than fine.
I've decided that I'm going to scratch build an entire car (what I've been thinking of doing for quite a while)
Using VW/Audi components
However I'm going to follow the example of one builder out there and build my front suspension so it cal be unbolted and pulled off in a single piece. Should I be happy with the setup I'll build a second one for the beetle. (was planning on staying within beetle dimentions anyway)
Old January 7th 2004, 17:18
Ephry73 Ephry73 is offline
Just came upon this thread. What is the status of the conversion? Would be very interesting to see how the fit would be on a Ghia. Any news? will be even more interesting if one could use aftermarket spindles as well.
E
