Old June 6th 2009, 11:02
Always good to see another project car hit the road. It's a great looking car. Job well done. Keep us updated.
Old June 18th 2009, 06:46
Xellex's Avatar
Xellex Xellex is offline
Thanks guys!
Originally Posted by evilC View Post
Nice looking car! Does it have the power steering you were looking at? If so, let us have some feedback>>>>>>.
It has everything installed, but the electro-hydraulic pump is not as simple as I thought at first. Normally there would be a sensor inside the steering rack, that "feels" the movement of the steering wheel, and turns on the pump, to assist you while you steer.
What we have to do now is to adapt a (probably hall effect) sensor somewhere on the steering column, to get the desired signal for that pump.
That's too complicated for me, but luckily I found somebody who can do it.
Otherwise, the steering is great, I did almost 1500Km with the bug now, and I can say I didn't notice ANY bumpsteer at all (and believe me, romanian roads are full of holes, craters, and bumps of all sorts ), everything seems very precise, there is absolutely NO play in the steering, and it takes just a bit more than 2,5 turns of the steering wheel from lock to lock.
So far I'm happy with it. The only thing I'd like to do is to beef up those rack mounts, just to be safe.
www.vw1303s.com
Old July 30th 2009, 03:34
Xellex's Avatar
Hi guys, check this out!! I just won this original Riechert cooling setup on ebay! I'm so happy, I had to tell somebody
Now I hope it arrives safely to my home, and I really hope I didn't bid against any of the people here on the GL forums.
File Type: jpg !BWhPjYgBGk~$(KGrHgoH-EQEjlLlwfrpBK(1Sby-Ow~~_12.jpg (24.9 KB, 75 views)
www.vw1303s.com
Old July 30th 2009, 07:42
Now if you put it under the motor you will be able to suck yourself down onto the road.
Old July 31st 2009, 15:53
Well done! Looks like a very complete set-up.
Old August 11th 2009, 08:45
Xellex's Avatar
Today it finally arrived, and everything seems to be ok. Now I have to start writing down a list of stuff to do in order to get the type4 engine working.
And in the mean time I wanted to do something better with my headlights, so I ordered another HID kit, I bought 2 secondhand FK Golf headlights, for the clearglass, and I did this:
www.vw1303s.com
Old August 11th 2009, 08:56
Xellex's Avatar
and this:
www.vw1303s.com
Old September 3rd 2009, 06:20
Xellex's Avatar
Hi guys! Time for a quick update: A few days ago I bought and installed a pair of koni yellow adjustable rear shock absorbers.
I am so happy with these, that I can say for the first time since the porsche conversion, my car has rear shock absorbers! The old ones, and the porsche 944 ones that I tried for a while were not doing absolutely anything.
And I started polishing the porsche cooling system. I want it to look good at least the first time it's on.
Slowly I'm trying to gather everything needed for the type4 engine, and to get to a definitive set-up, but i'm gonna need all the help I can get, since it's my first ever engine build. Hope it will turn out ok.
www.vw1303s.com
Old September 3rd 2009, 12:17
Looking good. Keep chipping away at it.
Old September 3rd 2009, 12:42
Bogara_ZO's Avatar
Good to see cars like this in the "neighbourhood" (I'm from hungary), congratulations. You should visit one of our VW meetings!
Old September 3rd 2009, 19:45
Xellex's Avatar
I sure will! But this year I've been a little short on money.
A few friends of mine went to the Gyoma&Rod on the 7-8-9 august 2009 and they say it was a blast.
www.vw1303s.com
Old September 4th 2009, 08:12
Bogara_ZO's Avatar
This year I missed Gyoma, but usually it's a good one. But there are many others you can visit, it's up to you. See you in 2010
Old September 30th 2009, 18:17
Xellex's Avatar
Took my car down the road again, for the last aircooled meeting in our country this year.
It handles well, but I'm still not completely satisfied with the rear setup. There is a wierd bouncing effect, after you hit some bump/hole on the road, the rear behaves normally, and after that it just bounces 1-2 more times. It's verry annoying because on some roads wich are not perfectly flat, and at a certain speed, it starts resonating (duuno if that's the correct word to describe it) and the whole rear goes up and down constantly.
This effect was lowered by the new koni shocks but it's still there. Right now the shocks are on the 4th click. (1=softest, 5=harderst). Should I set them to 5th?
The only thing I can think of is that the Porsche 944 torsion bars that I used are not good for this setup (maybe too soft?).
Should I switch back to the original 1303 torsion bars and give it a try? (man that's alot of work)
Any suggestions are more than welcome. Thanks.
And a few new pics:
www.vw1303s.com
Old October 1st 2009, 02:51
4th round in is already a lot for Koni's. The thicker torsion bars (23,5mm) from the 944 are very good and definately not too stiff. I use them as well and almost considering even bigger (25mm?)
There must be something else wrong...
You definately describe a too soft shock problem, so I am confused as well.
I use Bilstein gas shocks at the rear and Koni red up front. Very happy with the rear Bilsteins, they seem to have more rebound resistance. Maybe thats needed more at the rear?
Old October 1st 2009, 04:02
Jim's Avatar
Jim Jim is offline
Check how low is the rear suspension and if the bumpstop hits the upper end of the body.
If this happen then it should give you this extra 1-2 bounces.
I agree with Wally's thought, bilsteins + 23.5 944 torsions are one of the best choices!
http://www.bugaru.gr
EJ20 Suby Naturally Aspirated
