Old August 9th 2012, 15:38
Originally Posted by -Alex- View Post
Don't know that car, i have had that picture few years. I remember that you have aluarms also, what lenght shocks are you using?
Yeah, thats why I was interested: I now use 944 shocks (Koni yellow) and they have their (shortenend) bump stop about the same time as my (also shortenend) trailing arm bump stops. Its a good match therefore for my current ride height.
These in the pic seem shorter, more inbound travel possibility, which could be helpfull if you were to go even lower in the rear.
Looks like Remmele coil-overs to me, but not sure..
Old August 11th 2012, 21:55
volksmeister volksmeister is offline
What about Protech shocks recommended by ricola?
For those with steel arms, they come in 1.9" which gives better clearance from the CV boots and reasonably priced..
you can opt for extended base, choose btw bushing or bearings etc..
But gotta check if they have springs higher than 400lbs..
Be water, my friend..
Old August 12th 2012, 04:34
You must 'design' your own shock with them as they will ask what dimensions you'll want and you will have to wait and see if what they make from that is what will fit and work.
I'd rather have a shock/coil-over strut that has proved itself on my application (bug or 944), but the price difference is huge, which makes it all the more difficult..
Old October 12th 2012, 14:39
-Alex- -Alex- is offline
Third set for aluminum arms is under construction, same as last
AVO has also many shock lengths, i helped pick up coilovers from AVO for my friends homemade a-arm project for his 1960 beetle.
http://www.demon-tweeks.co.uk/motors...oilover-damper
Old November 5th 2012, 02:16
graham's Avatar
graham graham is offline
Hi Alex I wondered if these would be a good match for your uniball set up ? regards Graham http://www.ground-control-store.com/.../II=749/CA=219
gee dub
Old November 5th 2012, 05:31
Yeah, those are ok. They include necessary bolt extensions at bottom end. Choose atleast 450lbs springs, or better 500lbs. Ask from subaruengined beetle owners what springs they are using?
Old December 19th 2012, 09:10
kendy's Avatar
kendy kendy is offline
Where can i buy boots like this? I need it in europe.
Best Regards
kendy
Old December 19th 2012, 13:42
I got mine here:
http://www.jjcraceandrally.com/kit-c...-cv-joint-boot
Old December 21st 2012, 04:33
kendy's Avatar
thanks
Best Regards
kendy
Old January 14th 2013, 15:59
I have one set that its not complete, i can make a complete setup either for 944 aluarm or 944/924/bug steel arm for 650 euros, this offer is valid only up until next month or so
Old January 16th 2013, 06:16
kendy's Avatar
What kind of alu do you use? 7075 or 2017A?
Best Regards
kendy
Old January 21st 2013, 03:40
I use 7075-T6 only.
Old February 27th 2013, 16:59
Humble's Avatar
Humble Humble is offline
Is it too late to snap up that incomplete uniball set? I need it for 944T aluminum arms and correct me if i'm wrong but these will work with the stock porsche swaybay pckups that go through the arm and spring plate? PM with billing details
Old March 5th 2013, 11:35
jmd's Avatar
jmd jmd is offline
Humble,
I'm running your setup and am curious about what you're getting up to?
I am building my own uni's at the moment and would love to know how you're planning on using these parts?
more info?
Old March 5th 2013, 16:46
Who? Me? Humble?
What you want to know?
