Old January 5th 2004, 11:43
craazy Cooter's Avatar
Theres about an inch between the cooler and upper brace. I can vary the length of the spacers on my upper bar to lower it to acommodate the cooler.
Old January 5th 2004, 17:42
Alex's Avatar
Alex Alex is offline
The information was sent via email.
Old January 5th 2004, 18:55
Lazarus's Avatar
Lazarus Lazarus is offline
thanx alex i will contact him tommrow
Old January 5th 2004, 19:22
njv's Avatar
njv njv is offline
perhaps there should be a new thread started "what would people like to do group buys on?"
its just an idear:silly:
i wouldnt quite know which section to start it in?
neil verdon 66 sqr on irs.
Old January 5th 2004, 20:59
Alex's Avatar
Neil,
let me think about incorporating it.
Old January 5th 2004, 23:21
Alfito's Avatar
Alfito Alfito is offline
Thank you Alex, I will call him tomorrow too
I support Neil's idea
Regards
Alfito
______________
No Brain, No Gain
Old January 5th 2004, 23:32
Thanks Alex!
I agree on the group buy thread, I like Sandeeps airbox idea, I've been wondering where to get one!
John
VolkSport Kfer Gruppe
www.VolkSport.net
Old January 6th 2004, 01:38
So does anybody need help with creating their own? I can get my measurements if needed. Ever been to a car show and seen a bunch of cars with tons of bolt ons and no real creativity? Custom fabrication seperates your ride from the next schmoe. Those that aren't really interested need to start a new thread if you want a group buy.
Old January 6th 2004, 03:18
Thanx Alex. I am going to stay up and order it tonight, If I don't fall asleep.:silly:
I would like a group buy section.
Old January 6th 2004, 11:08
Racelook's Avatar
Racelook Racelook is offline
Yow Cooter.. I really really need any kind of measurmance (what i also have said in the second reply in this topic.. but sinds then it didn't goes over making your own :silly: ) so I can fab my own.
Have you welded some extra plates on your trannymountbar (I don't know the correct word in the english)?
How large are your roundbolts (circelbolts) (BADDD english )? Where did you get them from?
I'm still doubting on welding them on mij chassishorns or make my own just like your.. I think I make my own so I can always remove them if I want to install bigger engines,etc.
So if you can pm me some measurmance or post them in this topic..
In forward thanx..
Wiebrand
HOLLAND
B-Extreme B-Tuning.....
Old December 29th 2006, 21:40
AIRSICK's Avatar
AIRSICK AIRSICK is offline
Transmission Carrier Question
Originally Posted by Sandeep View Post
Don't forget that you have to cut the body slightly ('74 standard) if you are installing it (CSP 3-bar brace) with the body on. With a dremel, you can make the cuts look factory.
Also, make sure you have your axles in and the suspension loaded before you weld the links for the down tube from the shock tower to the frame horns.
You can weld in the frame horn link a couple of different ways but I decided to weld my link to the transmission carrier at the rear of the tranny that bolts to the frame horns. This will give me enough room for the suspension to compress while driving and have the axle not rub on the downtube.
Sandeep,
You said that you tied your frame horn links to the trans carrier. Do you have pictures of that? Did you fab your own carrier or are you using a stock piece? Are there any clearance problems to watch out for?
I would like to fab my own carrier and intigrate the mounts for the brace.
69project
Old January 3rd 2007, 23:29
LLVWGL LLVWGL is offline
digging threads up from the grave huh??
I was about to write "is this still going, i want IN!!!!!!", then i looked at the post dates. LOL
Old January 4th 2007, 13:37
AIRSICK's Avatar
Resurection
That's why you shouldn't post when your tired!
I found a nice heavy duty trans mount plate at CSP(California) for $29. I ordered it along with some Berg HD rubber front and rear mouns.
Old January 4th 2007, 16:38
Tedzbug Tedzbug is offline
i hate to ask........ is anyone using a brace with heaterboxes? pics?
Old January 5th 2007, 08:33
Bad bug's Avatar
Bad bug Bad bug is offline
Project 69 i will also be doing a 5 bar kafer cup rear setup soon as my brace comes in from miami. I also want to use the heavy duty tranny support as an anchoring point for the bar instead of the frame horn. I thing there should be a picture here to help us with the process.
