Old May 26th 2010, 19:52
Looks like you have your Tilton pedals in too. Moving along nicely.
Old December 18th 2010, 18:15
Well, time for an update seeing as I have 2 weeks off for the Holidays and need to make a big push to have this bug on the road for spring 2011.
Dash before: (needed to install a kickin stereo in high school )
Tried to cover it up and make it look acceptable
2 days of cutting / fitting / welding ... thanks for the donor dash Pete !
Cleaning up the "interior oil cooler experiment" as I now have an RX7 oil cooler up front
Old December 18th 2010, 18:20
chug_A_bug's Avatar
looks great Sandeep... hope to See it on the road this Summer
74 Std. GL
08 Vw rabbit
18 WR250R
07 Chevy 3500 Dually
Old December 18th 2010, 18:22
Re did the fuel system up front thanks to comments from the group ...
-8 line from the fuel tank to Aeromotive canister filter (100 micron), and then -8 to the swirl tank, -8 feed to the Bosch 044 fuel pump. Still need to run a -6 line from pump to regulator in the back, and then a -6 return line to swirl pot.
Front end complete except for plumbing up the brake / clutch hydraulics. The lines have been run, just need to terminate the fittings. Lanner is working on the new splindles, current ones are temporary so I can move the chassis around.
Old December 18th 2010, 18:27
Need to spend a few days fixing the rust in the rear area before I can place the body on the pan, and work on the heater channels.
Dash display coming along nicely.
I have all of the parts to put the long block together, then need to build a horizontal cooling system .... NEED TO GET THIS ON THE ROAD FOR SPRING 2011 !!!
Thats it for now, more progress as it happens.
Old December 18th 2010, 20:23
CLKWRK's Avatar
CLKWRK CLKWRK is offline
Looks great, I especially like the display.
Can't wait to see it (and maybe get a ride in it)
Bry
GL ghia restoration:
Old December 19th 2010, 07:41
I like all the control boxes!
The screen now reads s/th like 'Read the f*cking manual'!!
Old December 19th 2010, 10:24
Coming along nicely Sandeep!
Riechert still sells the horizontal fan set up.If you want one or need help ordering let me know.
Old December 19th 2010, 12:05
dub_crazee's Avatar
nice work sandeep! looks very trick!
Classic Car Revivals
www.classiccarrevivals.com
Old December 20th 2010, 16:08
V8SuperBeetle's Avatar
V8SuperBeetle V8SuperBeetle is offline
Nice work! I'm guessing you're going to repaint the whole car?
Old December 21st 2010, 09:40
Luismj's Avatar
Luismj Luismj is offline
Sandeep,
Nice job!
Only to show you an interesting solution that is being born in Brazil.
Full touch 4,3" realtime programmable or by computer. (This is not only one display is full programable injection)
http://www.fueltech.com.br/br/product/detail/198/ft400
The rest of the family is more simple and already a champion on the track.
CUP2 17x7x9 Brembo.w.Servo&Master.Cylinder/IRS/CB Dropped Spindle
GTI 2.1 16V Turbo Forged/Sapinho/Fueltech EVO-GL
Old December 21st 2010, 09:44
Luismj's Avatar
English....
http://fueltechusa.hydra.kinghost.ne...tail/215/ft400
Old December 22nd 2010, 08:22
Looking good.
Old January 3rd 2011, 17:49
ferfre007's Avatar
ferfre007 ferfre007 is offline
incredible! spectacular
The Käfer
Congratulations!
pereira zito in USA ?????? floor and skirting boards are not made in USA?
vw standar 1973
vw 1303 sunroof - Automatic Stick Shift 1974
vw variant squareback 1968
VW PARAGUAY
Old April 5th 2011, 16:07
Luismj's Avatar
Originally Posted by NO_H2O View Post
Looking good.
http://www.youtube.com/watch?v=Rm3pu...layer_embedded
FT400 I love it... im buy one!
