Old August 6th 2010, 11:12
I decided to just finish the wings, the metallic particles are so small I can't see them being painted separately from the body making any difference. I put on some wetter coats of the cellulose metallic and finished off with 3 coats of 1K acrylic clear.
For information, I used a cheapo spray gun for the etch and primer coats, then an Iwata AZ3 HTE2 spray gun with a 1.3mm tip for the colour and clear coats. This was all running from my 3hp 150l compressor that I made up a short copper section with water drain. It has actually given a really nice finish out of the gun with not a single run! A couple of small bits of dirt got in one wing but should easily polish out when it has fully cured. I had to paint the wings in two lots under my workshop porch bit as it was threatening to rain...
Old August 17th 2010, 16:09
OK, small update:
Decklid painted, no real problems, although I did sandblast the slats as they were too fiddly to sand nicely.
Bonnet finally painted. I've done this 3 times now! First time there was some striping visible in the colour coat as the passes weren't wet enough to flow into each other nicely. Then I got a really good second colour/clear coat and left it in the sun for a few hours to dry before putting it on some cushions in the conservatory just to have it out of the way but they left imprints all over the bonnet! I had to wet sand it all back and paint for a third time, I'm not doing it again!!
I'm working on the doors now and I've found out why somebody had put a gold pinstripe under the normal sidetrim. They had drilled one of the doors in the wrong place and the stripe was to cover it up! So, filler removed and the extra trim clip holes were welded up. Another useful tip: hold a piece of copper against the back of the panel and the weld won't blow through. I also had to repair a few local bits of the door bottom and the copper strip trick also worked well to stop the weld melting away the metal at the edges.
I'm definitely on track for finishing all the paint by the end of the month!
Old August 17th 2010, 22:30
johnnyvee's Avatar
johnnyvee johnnyvee is offline
Sooooooo sexy
Old August 18th 2010, 02:32
seangfy seangfy is offline
looks good!!! keep up the good work cant wait to see the finished project.
Old August 23rd 2010, 15:29
Doors painted...
More rust uncovered! This is the drain tube from the scuttle area by the wipers, it's a well known rust trap in 1303s so I wasn't too surprised. Repair from the inside of the car was the easiest way to go. Here I have opened out the rusty areas ready to weld new sections in.
To repair the tube I decided to use another trick I saw, bend some copper strip around the part and weld straight onto the strip creating the new section.
The outside surface is smooth (as it went straight on to the copper surface) but the inside needed some work with the die grinder . All good in the end though!
I've been busy doing minor bodywork too getting the main shell ready for paint, nearly there!
Old August 24th 2010, 02:19
Very good! This thing will be made mostly of welding wire when you are done!!
Old August 24th 2010, 06:19
Looking good. Love the color.
Old August 24th 2010, 14:04
Another good day today!
Body now etch primed..
and two coats of high build primer!
next job to wet sand this back ready for colour...
Old August 24th 2010, 20:28
You are moving right along! But, I think you need a step ladder to reach the top of the windscreen frame...
Old August 25th 2010, 03:26
Jim's Avatar
Jim Jim is offline
I can't wait to see it finished!!
Well done!
http://www.bugaru.gr
EJ20 Suby Naturally Aspirated
Old August 25th 2010, 03:29
I thought somebody might comment on the top bit, lol! It is in very good condition and only needed a bit of a rough up, no point covering it in primer again as it only needs colour..
Old August 25th 2010, 20:39
I knew there was a reason, but I couldn't help myself...
Old August 26th 2010, 08:13
aircool aircool is offline
Just finished reading this build post and I must say that looks awsome mate! I really look forward to some day seeing it in the flesh!!!!!
Old August 27th 2010, 13:40
Got the shell in paint today!
Now I just have to restrain myself for a while to let it fully cure...
Old August 31st 2010, 14:10
Last concentrated burst of activity before I start my new job tomorrow.
I made up a couple of aluminium plates to stop the torsion bars sliding inside, also a small bracket for the 2 new fuel pipes (5/16" kinifer) which ended up clashing with the body so I'll have to redo that!
You can just make out the chargecooler pipes coming out through a new plate at the front of the chassis, I also ran new front and rear brake lines. Instead of the usual cheap rubber body gaskets, I bought a long length of foam gasket and made my own VW style one, didn't take too long, hole punching it as I went to line up with the body mount holes and then glued any ends together with sikaflex.
Body on! I also mounted the bonnet as it was taking up far too much space in my workshop.
The rear frame will get stripped/painted, but that's for another time. it makes a very good carry handle when lifting the body about...
