Old March 6th 2013, 00:52
Humble's Avatar
Humble Humble is offline
jmd, I'm after few things really.
1. I'm looking for more adjustability out of the back end than I'm getting from the stock porche spring plates. It's also a pain to fine tune with the eccentric adjustment bolts.
2. I want to cut down on the rear end slop now that I'm playing with the much higher cornering loads that slicks produce. These plates and delrin pivot bushings should help with that.
3. I like giving back to the community where I can and getting suspension parts from members puts money into GLer hands.
If you aren't making a time attack car the stock parts are great. Even for intermediate track use on street tires they will hold up just fine. I'm at the stage now where I'm trying to go from the top 8% to the top 5% and I need reliability and repeatability.
Old March 9th 2013, 09:08
-Alex- -Alex- is offline
I am now offering bus kits also
Old June 21st 2013, 22:47
Humble's Avatar
Thought I'd put an update here and put up Alex's hard work. I finally had a chance to open the box and check out the parts. They are very robust and absolutely beautiful!
Old June 22nd 2013, 13:22
petevw's Avatar
petevw petevw is offline
Is it too late to snap up that incomplete uniball set? I need it for 944T aluminum arms and correct me if i'm wrong but these will work with the stock porsche swaybay pckups that go through the arm and spring plate? PM with billing details
Have any pics of where and how these swaybars mount?
'72 super
'65 bus
'52 split
Old June 22nd 2013, 18:07
Humble's Avatar
Here's a pic I took earlier, I can try and grab a better one from the backside later.
Old June 22nd 2013, 22:05
petevw's Avatar
Cool, thanks
'72 super
'65 bus
'52 split
Old July 14th 2013, 20:58
Bug@5speed(US)'s Avatar
Humble what size bar u running in the back.
I was going to use some 944 but with the Gwd rear sway bar mounts and our 901 front traverse it is not a good fit. The 944 seem shorter then the beetle ones by an inch or so. If I have to use the 944 I need custom endlinks at about 5 inches or so.
Thinking the beetle may be a better fit but can I trouble u to measure the short length so I can compare.
Rear IRS conversion bits look really nice need to check the price.
A
Alex Olaverri
Email: Bugat5speed@yahoo.com
Tele: 973 204-5463
Old July 26th 2013, 20:07
graham's Avatar
graham graham is offline
CNC made aluminum Uniball rear suspension system
Ordered my uniball set up from Alex , slowly getting all the parts together now.
gee dub
Old August 29th 2013, 14:59
These came out nicely, two setups are ready to go, Beetle with 944 aluarms and Bus T2 with steel arms.
Old January 4th 2014, 18:10
At the moment, until end of the february, i can sell 1-2 sets for 700€
Old January 5th 2014, 19:05
jmd's Avatar
jmd jmd is offline
Alex - is that price for your Beetle to 944 alu arms? With all the hardware? If so, let's talk about me getting one of those sets.
thanks.
jmd
Old January 5th 2014, 19:51
Same price applies to aluarms and steel arms.
Old February 24th 2014, 18:07
One set being made for JMD
Old February 27th 2014, 18:23
jmd's Avatar
jmd jmd is offline
I want to tell folks that might be considering this.... Alex has be absolutely fantastic to work with - his communication has been top notch and he has been great to do business with.
if you are nervous at all - don't be, just pull the trigger and get you some of these sexy ass parts!
Thanks Alex!
jmd
Old February 28th 2014, 05:59
I can still offer one or two sets less than 800€ before May, but at price 750€, due to a risen cost of aluminum and actual machining time.
As for timetable, usually i'll get the aluminum in 1,5-2 weeks, machining takes time 2-3 weeks. Bolts and uniball joints i'll get at few days.
