Old July 13th 2010, 11:02
scourtaud scourtaud is offline
Hi,
This is a neat looking car... And this engine is very beautifull... Hope it stays as clean as it now is...
Regards
Sebastien
Old July 16th 2010, 12:11
Bogara_ZO's Avatar
Here is a short video of the engine if you're interested. Enjoy
http://www.youtube.com/watch?v=4yMekwWfpdU
after that some oil appeared under the engine..still not sure where it is from I would say the oil filler or the tube of the pushrod but have to check it again.
Old July 16th 2010, 12:25
Bogara_ZO's Avatar
And the brakes I'm planning to use..
Old August 4th 2010, 12:59
Bogara_ZO's Avatar
Worked a bit on the car
Old August 4th 2010, 13:08
Jim's Avatar
Jim Jim is offline
Nice touches there!!!
http://www.bugaru.gr
EJ20 Suby Naturally Aspirated
Old August 4th 2010, 17:29
Looking good.
Old August 5th 2010, 18:23
johnnyvee's Avatar
johnnyvee johnnyvee is offline
where did you purchase the pedals from
Old August 6th 2010, 03:42
Bogara_ZO's Avatar
Ebay (UK) seller: Ian5718
Old April 13th 2011, 07:01
Bogara_ZO's Avatar
Hi, not too much to share, but at least the car is on the road again. New wheels and some new parts in the interior (steering wheel, shifter, pedals, oil pressure and temperature gauges, Sparco harnesses) for now. The breaks will be the winter project
Old April 13th 2011, 07:27
Bogara_ZO's Avatar
Now the bad point. I had some issues with the type4. One of the bushings (?) of the spark plugs had to be fixed -> engine came out, heads off (I repaired all of them)
Since the engine was out I picked out the lifters and pushrods as well to check if everything was OK with them. And I found this:
You can feel the little holes with your fingers on the top and side as well..now please tell me what do you think about it? Material defect or what? Has anybody seen lifters like theese?
I ordered the complete valvetrain kit as a package, so parts should work together well. The engine ran nearly half an hour (oil was OK) so the break in procedure has NOT finished yet..that's why I'm not sure about what to do. Try other lifters or keep theese
Old April 13th 2011, 21:28
Lazarus's Avatar
Lazarus Lazarus is offline
the camface on those look almost identical to the ones in my engine. i pulled them after my trip to and from daytona for winterjam last year. those side shots are a little strange. i woulld like to hear some other opinions though.
Old April 14th 2011, 11:39
volky00 volky00 is offline
where can i get those front bumper lights?? any link?
thanks in advance.
Old April 14th 2011, 12:57
Gerrelt's Avatar
Gerrelt Gerrelt is offline
Very nice car! I like the new wheels.
Greetings!
________Gerrelt
________homepage:gerrelt.nl
Old April 14th 2011, 15:32
Humble's Avatar
Humble Humble is offline
I don't like the look of those lifters at all and I'm not sure what that 2nd pic is with the deposits. I hate to say it but a "peace of mind" tear down might be in order. With wear like that, even on a new motor, I would pull it all out and check all bearings and wear surfaces. Probably not the answer you want to hear but that's what I would do.
Old April 14th 2011, 20:09
Bad casting is my guess, if the bores are OK you might be able to get away with just putting in new lifters.
