Old April 10th 2021, 13:34
Blizzard's Avatar
Blizzard Blizzard is offline
Thanks, the oilcooler is for a Mazda rx7 and fits perfect.
Old April 10th 2021, 13:50
Blizzard's Avatar
This is a very short film during the tuning of the carburators and jets.
AFR at this stage was running a bit to rich under acceleration.
https://www.youtube.com/watch?v=Qydgk9cmUnE
Old April 10th 2021, 14:09
Blizzard's Avatar
Serious question. Is this necessary or not?
Not so serious explanation why I did this. I wanted to go faster when driving in reverse, so I gave my airplane propeller some more air.
Mounted the number / license plate on longer bolts.
Old April 15th 2021, 16:11
Blizzard's Avatar
Tapped NPT thread into two regular nuts and welded those onto the rocker covers to connect the vent / oil return hoses.
Old April 15th 2021, 16:48
Blizzard's Avatar
The carburator tuning is done, so I no longer need an O2 sensor. I replaced the CSP Phyton with the GPP exhaust. It sounds great standing behind the car. In the car the intake sound is much louder than the exhaust. When buying this exhaust you can choose between 3 sizes. I chose the largest and most quiet, which is 160mm.
Old July 8th 2021, 08:51
Blizzard's Avatar
Update on the 2056cc Type 4
Intake manifold to cylinderhead port matching + heat insulator spacers
And port match the intake to the 44 IDF carburators + heat insulator spacers
Old July 8th 2021, 08:58
Blizzard's Avatar
Nothing more I can do at home on the engine.
Ready to take it to the next step.
Next update it will run on the engine stand.
Old July 8th 2021, 15:15
Clatter Clatter is offline
Love this build.. Thanks for taking the time to post up.
Old July 11th 2021, 09:33
Blizzard's Avatar
There is no take 2 for a first start. To dark and short, but it's proof it's alive.
https://youtu.be/sGn_HEXjngg
Old July 12th 2021, 06:11
Sounds very good
Old July 12th 2021, 06:29
Blizzard's Avatar
It sounds better in real life than on video. For some reason my camera mic. does not pick up the exhaust and induction noise but you can hear the ticking from the valve train very clear on video.
For the first start and cam brake in it ran very rich 11 12 on the AEM AFR gauge
I started with 55 Idle jets. And 1,5 turns on the Idle mixture screws. For the cam break in I only synchronised the carbs and let it run at 2000 rpm. for 20 minutes. Next time I will start testing different jets and tune the carburators. They ran surprisingly well straight out of the box.
Old July 13th 2021, 14:54
effvee effvee is offline
Nice taste, I like eye candy
Old July 17th 2021, 16:54
Originally Posted by wouter1303 View Post
Sounds very good
I second that, and that's out of the engine compartment.
Old July 18th 2021, 01:12
owdlvr's Avatar
owdlvr owdlvr is offline
More info on the exhaust, or a link?
Car looks excellent!
'71 Type 1 - Rally Project
'75 Type 1 - Family Heirloom
Old July 18th 2021, 03:41
Blizzard's Avatar
Link to his contact info.
http://www.german-performance-parts....ontact&lang=NL
Link to the exhaust on the German Performance Parts site.
http://www.german-performance-parts....id=962&lang=NL
