Old May 7th 2009, 02:20
petevw's Avatar
petevw petevw is offline
Got a set of BBS LM's out of Miami, last year. Found out they wouldn't fit without some thinking. The Remmelle hardware was hitting the inside of the wheel, so the wheel couldn't be bolted up. I was determined to make it work. Decided to try and make my own setup to allow clearance for the deep(ET65) rim/tire. I'm just finishing them up now, almost a year after starting them.
Should i narrow up that springplate some more?
Need to do get them welded and coated. Thinking silver anodize/powdercoat. Local shops?
Sooooo the 18x10 LM's will now fit. It's a very tight squeeze that will need some grinding of that 1 bolt.
Will the sidewinder exhaust fit on the inside of that tire? Who knows...... We'll see.........
I can't get the front wheels on. The LM's have a slightly smaller lug hole than the Dyno's. The Dyno's have always been a bitch to pull on/off. The studs look a little off. Could be bent? or not seated properly. Guess i will have to pull off the front brakes, AGAIN, and get new studs. Or drill the LM holes the same size as the Dyno's. Pic below has the wheel just barely on the studs. Couldn't push it on.
Lanner from Vdub Engineering fixed the front hubs to get the spindle nut sitting flush. This is how they were. Didn't like that at all.
'72 super
'65 bus
'52 split
