Rockers?
This has been an ongoing problem. I set my valves and the engines hums. With about two weeks of driving (regular), the car goes back to sounding like a diesel truck. My mechanic says my rockers are worn out. It used to do this prior to getting new valves, which I have now. But even with the new valves within 2 weeks maybe 3 they start knocking and get progressively worse.
So here I am, looking for a second opinion before I have to spend $$ again. Any thoughts. |
I had that problem, turns out the lifters werent turning and got destroyed.
I discovered this by pulling the sump plate and peeking up in the case with a pen light, I could just barely see the lifters all chewed up in there and bits of them were collected around the strainer Hope thats not you problem, thats a rebuild right there good luck
GL ghia restoration: http://s473.photobucket.com/albums/r...20restoration/ __________________________________________ |
What kind of push rods, and adjusters do you have?
1970 T1 W/MassIVe 2913cc RAT/?EFI? w/direct fire (very soon) and 915 trans 1962 SC 1776cc SP 944NA brakes, 993 wheels VKG |
I think:
Push Rod: Chrome alley Adjusters: Swivel Foot Sorry sort of an amateur |
If you do have true cromoly push rods, then they should be set at "0" lash, not .006, or .004. Stock aluminum push rods expand, cromoly does not. (stock go to 0 lash when at operating temps.)
The swivel adjusters, if not "real 911" ones...could be causing issues also.
