Old July 20th 2018, 04:43
Had a great track day for the first time after 6 years together with a good friend of mine in the grey german style 1303 with 2 ltr T4 and some Porsche friend of him.
Old July 20th 2018, 15:37
412STi's Avatar
412STi 412STi is offline
Zandvoort!!
thumbs up; thumbs up;
(smilies did'nt work!!)
Greetings Gerold
STi powered Typ4 in the works...
R.I.P. 1302/'72
Old July 20th 2018, 18:26
H2OSB H2OSB is offline
You live my desired life, Wally!
johnL (aka H2OSB)
Old July 21st 2018, 05:26
Haha! I'am sure it isn't that desired but thanks for the nice reaction
I did find an issue with the limitations (lets hope its just that) of the breathing capacity of the engine as on contineus high revs plus boost, too much oil fumes came out of the breather box.
Just added the little can under the oil plate so sump is a little bit deeper, so the dry sump can do its job better. Also ordering a larger breather box.
Hopefully both these will keep it under control.
Old August 23rd 2018, 17:08
My girl driving shotgun, made this small clip
https://youtu.be/032bzvlWbLg
Old September 7th 2018, 23:51
Nice video, my wife would probably freak out on track going that fast!
Old September 8th 2018, 01:53
Nice video, your gearbox sounds like mine
Old September 8th 2018, 22:06
owdlvr's Avatar
owdlvr owdlvr is offline
haha, I WISH mine sounded that good :P Everyone who rides in my car asks if it's about to explode.
'71 Type 1 - Rally Project
'75 Type 1 - Family Heirloom
Old September 9th 2018, 15:49
She's awesome: wasn't even that impressed with our speed...
We run the same gearbox obviously hey Steve
It is indeed pretty loud on lift-off. Since its still in one piece after all these years and abuse, I'll leave it be
Old September 10th 2018, 10:51
Love my G50 it still works after all hell I give it
Old September 10th 2018, 18:02
That sounds delicious!
H2OSB
johnL (aka H2OSB)
Old April 7th 2019, 03:47
Well, not everything works out with my builds too as these pics prove:
Torched a cylinder and head big time!
Root cause probably the one-off cast cylinders. No matter how thick the walls were...
Partly also my own fault as I didn't retorque the heads more often, which would have been more wise because the cast cylinders did need more 'seating' then I usually am customed to. I noticed this when disassembling the engine: head torque was too little on the other cylinders, so thats probably what started this.
Still, all other cylinders also showed a much larger bore up top then bottom of the cylinder (!), so they just didn;t stood up to the cylinder pressures I ran anyways. That also explained the excessive breathing I experienced: the rings just couldn't keep it sealed up top in the cylinders..
Anyways, for a 'quick' fix I bought a set of the AA 98mm birals so I could reuse at least my pistons.
Head is fixed at the moment already and I am reassembling the engine again
Old April 7th 2019, 04:29
effvee effvee is offline
Walter, what happen to your Ottinger Cylinder?
Old April 7th 2019, 04:31
Walter, what happen to your Ottinger Cylinder? The width of the sealing surface looked thick enough.
Old April 8th 2019, 02:48
I sold that 66x103 engine about 7 years ago and started building this new 74x98 one, which is partly what this thread is about. Pay a little attention brother
Currently Active Users Viewing This Thread: 868 (0 members and 868 guests)
