Oil Pressure at cranking - What should it be?
As title says : Oil Pressure at cranking - What should it be?
Also - Whats the stock pressure relief valve set to? CHeers, Sam C PS. Engines in, piccies soon...
1973 1303 (super beetle) in Jaguar British racing green, Raby 2270, B spec gearbox, Lots of carbon fibre, Wolfrace Octane Black 17x7.5, Goodyear Eagle F1's, Kerscher suspension front and rear, kamei airdam in carbon, corbeau seats, momo millunium steering wheel. CDT eurosport 6.5 front speakers, IDMAX 12D2 sub, rockford old school amps. |
Piccies
The oil pressure we are seeing at cranking is reported by my VDO gauge as 40 PSI, the TIM gauge (which uses a capillary) is reporting 48 PSI. Thats with bare minimum connected to test it... No alternator, No MSD, No Fuel, No plugs in holes. Is this good or bad? Also, it doesnt quickly show pressure, it takes about 5 seconds to build up the pressure... Warning light goes out after one second. Cya, Sam C
p s i
40 psi is good. 60 is better. try using an adjustable relief valve.
my 1641 has worn cam bearings, and at 180F the 10 PSI oil light comes on. I installed the adjustable valve, and kicked the pressure up 10PSI. try a high volume pump. oil pressure is everything. |
Cheers for the reply... Bit late though.. Engine is in and fully working now
Thanks anyway, Sam C
then take it back out dammit!
