my 61 project
After 2 years we are almost done. Its running and driving, we just need to get the interior finished. Of course there are things I am going to adjust/change when the weather changes and I can't drive it for the winter.
Thanks to the help here we have a really nice "driver" that handles great and stops really well. Engine 45 Dellorto carburators CB 3125 hex bar linkage and air cleaners CB offset manifolds match ported by K-Roc CB 1154 82mm stroke super race crank CB 1290 super race rods 5.50” 90.5 B Cima Pistons CB straight cut gears CB 2288 cam CB 28mm Lifters CB 1.4 Rockers Heads by K-Roc : 40 X 35.5 heads 9.4 compression 12lb chromoly flywheel Kennedy stage 1 1 5/8 A1 sidewinder exhaust system (the best money you'll ever spend on an exhaust) Schaedek 30mm oil pump puma low profile shroud CB 1770 thin line oil sump 1.½ quart Body 1961 pan 1969 IRS 4 wheel disc brakes 85' 944 porsche front suspension 2" narrowed beam with airspeed sway bar Front wheel hub machining for the brakes by VDub Engineeering. rear suspension 85' 944 everything from the torsion bar back and added a 3/4" swaybar. 3 bar kafer brace from VDub Engineering. Powder coating was all done at home with an Eastwood kit and an oven in the garage. |
Looking very good, what's the name of that color?
VW Sea Blue L360
Popular in the 60's |
brakes
Nice looking car, Bullyboy. I see that you have the 944 brake conversion. That is the same setup I am going to install on my 72 Super. Can you give me some more info on the brakes and wheel/tire size. Did you use the 944NA MC? Did you have any problems with brake bias or did you use a propotioning valve? I suppose tire size would be a factor. I am using 205/55-16 front and 225/50-16 rear. I am waiting to get my re-machined parts back from Lanner @ VDub Engineering, so any info you can give me would be helpful Thanks, Eric.
that car is awsome
YEAH ITS GOT A HEMI |
Very nice.. the wheels look like they were made for that car! Good choice!
You got mad powder coating skills!!!
My newly Updated Webpage..that actually works now!!! |
Hi,
how do you find the exhaust system? Loud, ok? and does it need to come off to check valve clearances? |
Fit and finish is awesome. Sounds like a stocker with a growl at cruising speeds. Then it really roars when you get on it. I drove it past some friends the other day at WOT and they said it was pretty quiet. I like it much better than the merged S&S with fatboy I borrowed to break-in the motor. Valves are no sweat. 3 bar kafer brace from Lanner. Zero wheel hop Gauges |
Did someone say powder coat?
The wheels are decent but they are far from perfect. They were stripped, blasted, and a coat of Eastwoods single stage almost chrome. Dorinda kept bugging me there were too many colors. Compaired to her 73 Super she had flat black, gloss black, and mirror black (yawn) |
Looks cool.
I'm currently running a merged 1 5/8 which had a fatboy (now an offest 2 1/2" muffler) and the noise is really getting to me after 3-4months as a daily driver. Plus having the car on it's guts doesn't help either... Thanks for the feedback. Appreciated :agree: |
what kind of bump stop did you use on the 944 rear arms?
drilled and tapped the arm and then used the urethane bump stops
