Old October 14th 2008, 22:57
pantswagen pantswagen is offline
so to fit a 944 s2/turbo front spindle can I just.....
1. use a stock s2 strut but with one of them tapered inthe middle springs
2. use the stock top, and drill my strut tops 4 bolts, instead of 3 - whilst i have the tops off, fitting the new springs for reference.
3. fit a kerscher ball joint to a 3 bolt lower control arm, and fit the spindle - do the lower arms differ 2/3
4. will i have to fit the steering rod end the other way up? do i 'just' re-cut the taper, and use a fatter tapered rod end
5. just got some miglia cup 2's - thinking i need the small offset/et -15 on a 7.5, can i then use the 7j et55 i have,
6. can i fit the 185 17 inch tyres of a vauhall vx220 on a 7j
7.most importantly, will the camber be out,.
