What's the difference???
I need early 944 rear hubs and backing plates/caliper mounting brackets for my 993 conversion. Will late 85 work (85.5)? What's the difference between the early and late and why won't they work if so? THANKS!!!!!
Julian '74 Super "If you are under control you're going too slow" - Parnelli Jones |
No one ???
Well, you can use every year 944 NA & 924 TBO/GT rear caliper brackets and hubs are all the same.The differences you are refer to are for the later aluminium trailing arms who the caliper brackets cannot be removed (one piece casting)... Rgds,
Jim Andritsakos 74 1303 GL (project) 75 181 ex bundeswehr / 85 T3 Panel 86 T3 Syncro ambulance / 87 T3 Syncro doubledoor 16 89 T3 Syncro panel |
Thanks!! The alum. are a wider track if I remember correctly, so I probably don't want them. Am I right?
The only difference is the wider track... Up to you if that is what you want to do or not.
Pillow is correct.
1986 only 951 has are a bit wider (24mm) and 1987 and up are (64mm) maybe I don't remember the widths right at the moment but I can check this out if you like. rgds
Thanks fellas! I don't want any more track so I'll stick with the early set-up. Now where to find 'em.
