  #18
Old June 28th 2007, 14:09
Sunroof53's Avatar
Sunroof53 Sunroof53 is offline
More ways to skin a cat.
Heres some photos to show the vw disc spindle built up to porsche diameters (welded and turned between centres).I took 3.5mm from the back of the hub and rear counterbores .Made spacer to move front bearing forward 2mm to correct the pitch as much as i could.Made a spacer for the seal diameter to use 62x8x45 seal.This increased the track by 3mm each side.If i did another i would probably try it the way you did .It was basically easier for me to do it this way ,as i could do it myself.Did you use a back plate ?
The wisest mind has something yet to learn
