Need some alignment advice...
I'm planning to get my '69 Beetle off the jackstands and to the alignment shop this week -- after 9+ years of work . It's a fairly hot street car (2332, 44IDFs, CB wedgeports, FK-47, 8.7:1) that I plan to use as a weekend driver; twisties and straight. What do you guys suggest for alignment settings?
I've heard -1/16" toe for the front. Is that at the tire edge or wheel lip? What about the rear? I've heard to set it -1/16 to neutral toe. What about front and rear camber? Actually alignments specs would be great. Front: *2.5" narrowed adjustable ball joint beam set to neutral height *2.5" lowered spindles *Stock '69 bug steering *GR2's *3/4" Sway-Away sway bar *205/55's on 16x6 Fuchs *spare tire in well Rear: *24.5mm torsion bars with urethane sping plate bushings *2.5" lowered with adjustable spring plates and urethane bushings *GR2's *3/4" Sway-Away sway bar *225/50's on 16x7 Fuchs
Kafer_Mike Build 'em fast...or let 'em sit. |
