Old January 17th 2006, 01:48
Here's the A4 racers pedal assembly with the 4" false floor below it. The driver is back a bit to help weight balance of the car.
Here's the reverse swing pedal assembly in position. It sits just a bit lower than the stock pedals, a position I prefer. I'm using my M3 pedal positions as a reference, and they are just about the same.
Here's the stock MkIII VW clutch MC after I removed the studs.
I had to grind off one of the mounting posts on the base for the pedal assembly. This area is where the assembly is right up next to the steering column. Everything just fits!
