  #16
Old July 6th 2004, 01:28
Mysticle31 Mysticle31 is offline
less the high end paint and frame off doesn't seem that expensive is it?
As I read in "The Perfect suspension" Is it true that the early 911 Had the same handling characteristics and weight dist. as the super beetle? How do I go about extracting the most handling potential out of this car? (less tubular frame) Nice extra Firm ride prefered!
Without lowering the front of the car. Lowering a macpherson strut suspension is bad for handling becouse it thows off the roll center (the roll center drops faster then the cg) Or if theres away to maintain that geomitry that I am not fimilier with. (Idealy the control arms should be.. say .5 inch higer on the inside then the outside depending on spring rate)
