#16
I love your car...
#17
Thanks Oasis, Kulein
Unfortunately then the clutch slips from the oil leak behind the flywheel, so the engine must come out again. Very frustrating... The cam is therefore difficult to judge by now, but large LCīs may give less cylinder pressure and I am not sure if that is good yet. Like I noticed on STF, webcam has decreaed the LCīs of the Web 119... maybe they or their customers didnīt like the negatives over the advantages of running large LCīs... Thinking out loud, maybe large LCīs are better for engines that run high CR on turbo engines... But maybe weīre going too deep here The CHTīs were very good btw. Nr. 3 showed just a tad over 350F when it was full boost hauling down the straight at the track. Oil didnīt even get over 85 degrees Celcius after half an hour full racing (I didnīt really spare the motor...). Quote:
Datalogs were boring again (IAT 21 degrees Celcius at a 15 degree day..) and I still havnīt been able to save a log while at the track. Since data is gathered continiously and I drove 2 hours back fron the track, previous data is autonmatically deleted. There is a on-off switch to be made, but I still havnīt gotton to that. Long story short, nothing to show you ... You īll have to take my word for it |
#18
Wally, the myth buster.
#19
This is what a track day does if your having fun...
(the curved exhaust exit is because of noise restrictions...) |
#20
You won't believe this...
I have a slight clutch slipping problem if the turbo came in hard (and it was only 7 psi) on the track last friday. Pulled the engine (again...) and found a dry bell housing behind the flywheel. So I looked at the clutch disk more closely: Indeed: the springs hit the flywheel and caused some part/not-engaging on one side... I probably got punished for using a VW disk with a G50 center which also gives the G50 springs (?) (although Kennedy should have known this too I suppose)....who else is crazy enough to try this huh? Problem probably easily solved by turning down the inner part of the flywheel a bit to clear the height |
#21
(Or anything else that requires a complete engine teardown) |
#22
My thoughts exactly!
#23
Still can't believe it looked like this:
Good work Wally!
'72 super '65 bus '52 split |
#24
I can, cause mines been replaced from the windshield forward by PO, and both sections right below the "antenna" area are already getting rust wholes again, so I'm RIGHT ABOUT where wally was in that pic, except I haven't gotten mine apart yet...
Guess I should learn to weld and get a welder, seems worth it, I had pondered getting another body... |
#25
Finally, the engine and tranny are holding their fluids where they belong. After all was tried, the O-ring seal from the tranny needed to be replaced and one of the rear bellhousing plugs on the engine wasn't sealing...
But its all good now and boy, it is fun to drive again with the boost turned up a bit more It was only 7 psi at the track day and now with new oil, heads retorqued, valves adjusted and rings that have very probably seated (engine doesn't smoke at all), I tuned the PWM valve to give about 10-11 psi. I am sure this engine will run over 6K and still make more power, at least that how it feels like. It sure is scary though to feel/hear/see the boost come on when you're running a new engine. Today was a bank holiday over here and tomorrow everybody took the day off, so me too. Got some more test 'n tune to carry out |
#26
Today I tried to get a bit above 10 psi, but the clutch is saying: "enough is enough, I am not transmitting more torque..."
Slipping at anything above 0,8 bar and you can smell it as well. I will probably need to phone Kennedy on monday... |
#27
Let's face it, that's far from the worst problem you could have!
http://www.ricola.co.uk |
#28
True, but I really was hoping to have the engine INSIDE the bug a bit longer this time...
A friend suggested a dual organic disk and floater plate set-up. Hope KEP makes that for my weird combo. |
#29
saludos desde Paraguay!!
se nota que se trabajo de cero!! tiene un hermoso motor tipo4!!! excelente!!
#30
That part I understand
Gracias! |
Currently Active Users Viewing This Thread: 6832 (0 members and 6832 guests) | |
