Old May 1st 2004, 23:37
Draft of new club rules
I just spent a bunch of time typing in a nice post and lost it all.
so i'm not doing it again.
Anyway, see below (it is a paste from a Word doc so excuse the formatting but i think it is legible) and shoot back any comments. There are still holes to be filled and key decisions to be made. Two things that need the most attention are naming the classes of cars (Class 1 and 2 are only there are placeholders) and determining dues and car membership rewards (shirts or what).
Keep in mind that we are trying to allow for people of all budgets and mechanical apptitude to fit within the rules while still trying to maintain some level of quality of what our interpretation of a GL car is and what we want VKG cars to be.
We will adopt it as soon as we feel the details are firm.
__________________________________________________ ____
VKG Club Rules/Benefits and Car Requirements
Club Rules and Benefits
Membership in the VKG is structured as membership for the person and a separate membership for your car as a VKG car. The breakdown is as follows:
VKG Member: Basic membership in the VKG is open to all. You may have a German Look car complete, under construction, in the planning stages, or no car at all and just want to hang out with GL junkies and you can be a VKGer. This allows for anyone to be part of the club. Any and all are welcome. $20 dues are paid annually.
With club membership you get a VKG membership dog tag keychain (exclusive “Charter Member” tag to the first 50 members), club sponsor discounts, and access to exclusive VKG merchandise and club newsletters.
VKG Class 1 Car: All German/Euro Look Air-Cooled Volkswagens (any year) that meet the minimum Class 1 points for each category as noted in the Car Requirements section. A $?? (thinking $20-40) one-time car membership dues payment is required.
With a Class 1 Car membership you also get a high quality VKG window/body sticker to identify your car as a VKG car and some kind of special promo item we need to define like t-shirt or something.
VKG Class 2 Car: All German/Euro Look Air-Cooled Volkswagens (any year) that meet the minimum Class 2 point for each category as noted in the Car Requirements section. A $?? (thinking $50-70) one-time car membership dues payment is required. A car being upgraded from a Class 1 car will be discounted.
With a Class 2 Car membership you also get a high quality VKG window/body sticker (or maybe we can do a badge) to identify your car as a VKG Class 2 car and some kind of special promo item we need to define like work shirt or custom jacket or something.
A car should not be shown as a VKG car (with any VKG stickering) until the requirements for the given class have been met.
We are predominantly a South Eastern US Club, but we are open to anyone that would like to join.
Car Requirements
The new VKG car requirements are based on a point scoring system to determine a car’s compliance to the VKG philosophy of well balanced upgrades through the car systems. This scoring system, while it may appear like a bit of overkill, will help the club ensure that all club cars are built to a standard of quality to better the car’s performance and safety as well as visual appearance.
The points scoring system is based on a minimum level of upgrades on the car in each of several categories. The bigger and better the upgrade, the more points it counts for. Having to meet a minimum score in each of all the categories prevents someone from just throwing some Porsche rims on a car and some carbon fiber accents and calling it a VKG car.
There is no overall score. You must meet the minimum score in each category. As you will see, it doesn’t take much to meet the minimums in each category to have a Class 1 car, but even these minimums across each and all categories will greatly improve a stock VW. To have a Class 2 car, you must meet the Class 2 minimum in all categories.
The list of upgrades can also serve as a reference of what options should be considered when you are considering how to improve your ride.
1. Engine: Open to all air or water cooled engines. Unlimited modifications allowed to engine to improve performance.
Scoring:
Modification/Upgrade Points
Aspiration:
Ported manifolds 1
Dual carbs 2
Fully-merged header 3
Non-stock exhaust 2
Turbo 5
Non-stock fuel injection 3
Cooling:
Engine:
911 cooling system 3
DTM-style cooling system 3
German sheet metal 1
Oil:
External oil cooler 2
Larger oil pump 2
Dry sump 3
Deep sump 1
Full flow 1
Clutch/PP/Fly:
Upgraded clutch 1
Upgraded pressure plate 1
Lightened Flywheel 1
Displacement:
Up to 10% increase in displacement over stock 1
11%-25% increase in displacement over stock 3
Over 25% increase in displacement over stock 5
Internals:
Nickies 4
Upgraded camshaft 2
Upgraded rods 2
Dynamic Balancing (complete reciprocating mass) 2
Heads:
Ported and Polished 3
Increased Intake and Exhaust ports 3
Solid rocker shafts 1
911 adjusters 1
Ignition:
CDI 3
Rev limiter 1
Bosch 009 Distributor 1
Pointless (non-optical) Distributor 2
Optical Distributor 3
Engine Swap:
Non-TIV to TIV 5
Other (WBX, Subaru, etc) 5
CLASS 1 MINIMUM SCORE: 5
CLASS 2 MINIMUM SCORE: 15
2. Transmission: Unlimited modifications allowed.
Scoring:
Freeway Flyer 3
901/915 trans 5
5-speed Berg 3
Other tranny 3
100mm CVs/T181 Flanges 1
CLASS 1 MINIMUM SCORE: 0
CLASS 2 MINIMUM SCORE: 3
3. Brakes: Unlimited modifications allowed.
Scoring:
Non-T3 to T3 drums 1
Ghia two pot front discs 2
Other two pot front discs 3
Four pot front discs 5
Ghia two pot rear discs 2
Other two pot rear discs 3
Four pot rear discs 5
Upgraded master cylinder 2
Stainless Steel soft brake lines 1
Vented rotors 2
Cross-drilled/slotted and vented rotors 3
Stock front or rear drums -1
CLASS 1 MINIMUM SCORE: 2
CLASS 2 MINIMUM SCORE: 4
4. Suspension: Car should be lowered front & rear. Unlimited modifications allowed to improve ride, handling & chassis strengthening.
Scoring:
Lowered front 2
Lowered rear 2
Front anti-roll bar 2
Rear anti-roll bar 3
Coil-overs (points per axle) 3
Performance shocks/struts/springs 1
IRS rear from swing 2
Aluminum trailing arms 3
Transmission brace (Kafer Cup style Brace) 4
Front strut brace 2
Narrowed beam 2
Narrowed arms 2
CLASS 2 MINIMUM SCORE: 10
5. Wheels: 16” or larger Porsche or aftermarket wheels required with low profile performance tires. Only exceptions to this rule are 15” Porsche wheels, but the previous is strongly preferred to stay true to the look. No stock VW wheels or classic VW wheels (i.e. Empis or BRMs).
Scoring:
15” Porsche wheels 1
16” and larger wheels 3
3-piece wheels 5
High Performance tires (H or V rated) 1
Ultra High Performance tires (Y, W or Z rated) 3
Bolt pattern adapters (not spacers) Not permitted
6. Body: Body modifications should be functional & tastefully done and true to the style. Paint can be stock pallet or custom but should have a European influence.
Scoring:
Lexan windows – rear 2
Lexan windows – quarters 2
H4 or HID lighting 3
Third brake light 1
Custom paint color or scheme 4
Carbon fiber body panels or running boards 5
Non-stock mirrors 1
Single or 911 wiper conversion 2
Painted/Blacked Out trim 1
Shaved trim 2
Weight decrease of 1%-10% 1
Weight decrease of 11%-15% 3
Weight decrease of over 15% 5
CLASS 1 MINIMUM SCORE: 1
CLASS 2 MINIMUM SCORE: 5
7. Interior: Performance/Sport influenced (bolstered seats, sport wheel, upgraded shifter, etc), Race inspired (i.e., race seats, harnesses, roll cages, safety equipment & extra gauges), or stripped. No stock interiors.
Scoring:
Sport/Racing seats 3
Sport steering wheel 2
Upgraded shifter 1
No back seat 1
Roll cage 5
Harnesses 3
3-point seat belts 1
Fire extinguisher* 1
Extra gauges 2
Porsche gauge cluster 3
Carbon Fiber components 3
CLASS 1 MINIMUM SCORE: 3
CLASS 2 MINIMUM SCORE: 8
8. Theme: Overall theme of the vehicle should be consistent & carried through, from the inside out. Don't mix styles.
*MANDATORY items
zen
Old May 2nd 2004, 11:11
boygenius's Avatar
Well it looks like I'm a class 2 car in the works. I like the rules and I really like the mandatory fire extinguisher, you can never be too safe.
Old May 2nd 2004, 11:29
I have gone over the new rules with Zen and I think that this will be a good format. I think it will keep our cars well balaced but a class 1 car should still be within the reach of most budgets. There was a saftey factor in mind as we started this system. A fire extinguisher was made manditory and a car with a 120 HP engine, no seat-belts and drum brakes is not very safe car(just 1 example). I'm sure there are some things that have been overlooked, so lets put our minds together and see what we come up with.
Old May 2nd 2004, 12:23
speaking of seatbelts, that is one thing i would like to change. we listed points for 3-point (which i don't feel could or should be mandatory due to early bugs and speedster kits that may want to stay with laps even though it is not preferred), but i do think there needs to be a zero point entry for any seat belts and make it mandatory.
zen
Old May 2nd 2004, 12:51
boygenius's Avatar
Engine Swap:
Non-TIV to TIV 5
I thought that only german water cooled engines were allowed. I guess that was one of the rules changed. A 300 hp wrx engine for 3K is calling my name.
Oh yea. I didn't see any points for the 944 single piston non turbo brake upgrade.
Old May 2nd 2004, 12:56
that is one of the bigger proposed changes. doesn't mean that it won't change back, but we wanted to have it out there for feedback. personally, i am in support of the change. as long as the swap is a quality one (not having half the engine sticking out of the back of the body panels or a radiator strapped to the hood), i am fine with it. panelfantastic is evidence of what a clean swap is.
944 NA brakes would be covered under...
Other two pot front discs - 3
so 3 points for that one.
zen
Old May 2nd 2004, 13:29
Panelfantastic's Avatar
Thanks for the mention.
I didn't mean to start a revolution or push the club in a direction we didn't want to go. My allegiance definately does not hinge on acceptance of the unusual (crazy) choices on my bus. I support the club regardless of my "poor stepchild". I still have other GL projects brewing in my brain . I don't want the powerplant options to make anyone feel that we're losing sight of a true "German" look club, but sometimes options are good...as long as the general theme is maintained.
I vote at least lap seatbelts are mandatory.
No current VW projects
54 Chevy wagon LS2 AWD
56 Chevy Panel "Lost Cause"
VKG Bastage child
Old May 2nd 2004, 13:46
I'm for manditory lap belts too. :agree:
Old May 2nd 2004, 15:36
boygenius's Avatar
One of the factors for a GL car is that it should have some "GO" along with its "SHOW". Yes a massive type 4 or a turbo type 1 would be an awesome engine but they aren't in everybodies budget. Why spend upwards of $7,000 for a well built 225hp type 4 when you can get a 227hp wrx engine (for example) for $3,000. If you want to go fast and don't want to pay for it through the nose then an engine swap is the answer.
Old May 2nd 2004, 17:45
only a couple of responses so far, but of you guys...what about the name of the classes of cars and what do you think is fair to consider for one-time dues for entering the car for membership. the whole idea there is to recognize the effort put into the car to make it a true GL, ensure the quality of the cars being labelled as VKG cars, and to have some little special VKG type reward or recognition (even if it is really self-funded ).
so the dues should only be what it would take to cover the recognition award and a little extra to help fund events. hopefully we get the ball rolling on membership so we really even have money for events. so far we have just been able to cover promo stuff like the banner, stickers, MUAD award and dog tags (which are coming this week).
zen
Old May 2nd 2004, 18:04
boygenius's Avatar
I think the dues are right on the money.
Just pick the middle number. $30 for class 1 and $60 for class 2.
I really don't have a problem with the class 1 and class 2 names but they can be a little confusing since class 1 is normaly the better class. I think about them for a while and see what I can come up with.
Old May 2nd 2004, 18:16
I vote for Dave to come up with class "names" .
"cost plus a little extra". That should apply to all dues and expenses. We aren't talking about a lot of extra money and having that little extra to help at events and promote the club just makes sense.
VKG Bastage child
Old May 2nd 2004, 18:24
boygenius's Avatar
As for the class names.
for the level 2 .... fast Komplett = nearly complete... since the level 2 cars pretty much have all the goodies on them already but eveybody here knows that your car is never done.
And for level 1...
Arbeit gerade beginnen = just starting work.
Eintragung = entry.
Just a few ideas...
Old May 2nd 2004, 18:39
kenfyoozed kenfyoozed is offline
i think the proposed rules are great. i have no problem with them .... except they tend to lean more to the porsche side of things.. .. but with the plans for my car , it will still be a class 2. so no harm no foul. keep the good ideas coming.
Neil Robinson
REMEMBER ... think VW not PORSCHE
Old May 2nd 2004, 20:11
Me? .....
