Old October 30th 2020, 07:53
subamaniac90 subamaniac90 is offline
Tie Rod length
Anyone know the exact tie rod length with steering rack and 944 spindles?
Old January 22nd 2021, 17:54
flat flat is offline
Late reply but 500mm
www.vdubengineering.com
Old January 25th 2021, 16:47
H2OSB H2OSB is offline
Flat makes them, but I will tell you, if you can come up with them, the rack&pinion tie rods on the STEERING BOX is long enough. Now, if you have the rack already, you'll need to go longer.
H2OSB
johnL (aka H2OSB)
