Old February 6th 2014, 01:07
effvee effvee is offline
Ring& pinion
Hay everyone, I've been trying to get someone to make me a ring& pinion set for the berg 5 speed conversion. Not only for the berg setup, but also that will fit my Quiafe ATB unit in 3:44 ratio.
A company said before they can give a quote they wanted to see specs,I don't have any specs or print. Does anyone have a print on a 5 speed ring& pinion. Wheedle,Berg, both use a weld up method to add the fifth gear to a 4speed r&p
