Go Back   GermanLook Forums > Classifieds > Wanted
Old August 25th 2003, 08:24
T-2/181 CV's and T181 Output Flanges
need a pair of T2 or T181 CV's (outer if that makes a difference) and T181 output flanges. i have some stuff that i could trade or cold hard cash!!!!
zen
Old August 27th 2003, 14:54
Stuart Stuart is offline
VW 181 flanges
Is that Atlanta in the USA? If so, check
http://www.thingsunlimited.net. They sell these parts.
Greetings
Stuart
Old September 12th 2003, 08:26
Augie Augie is offline
I have a pair of new LOBO cv joints for a Thing, pn 113 501 331D. Also I have the boot kits for them as well. Let me know if you still need them. Sorry, I don't have a set of flanges.
Old September 14th 2003, 05:23
Bruce2 Bruce2 is offline
Augie, you should check that part number. A Thing CV joint starts with a 181, not 113.
If anyone else wants T181 transmission drive flanges, send me an e-mail at: brucetweddle@canada.com
Old September 14th 2003, 09:28
thanks for the info guys. i am having to go back and reevaluate what i really need. some of it has been discussed in threads on here. looking like i will stick with T1 flanges if i can. trying to verify needed axles and CVs now.
zen
Old September 14th 2003, 20:25
chigger chigger is offline
The axle splines are the same for both the T1 and T2 axle flanges and trans flanges. You can mix and match. You must use a T1 axle with a T1 trans and a special axle with a T2 trans. The T1 axle also is the right length for a 901 and 915 porsch trans. The T2 flanges both in and out are available from most on the off road suppliers of buggy parts. Swayaway has heavy duty axles if you decide to snap one.
Old September 15th 2003, 09:08
Some Thing parts start with a 181, but shared parts keep their original number, from what I have seen. Thing CV's are the same as a T4 CV. (same OD as a T2, but supposedly has more angular travel). I was also told that the driveshafts are different in length than T1, but have never compared them side by side, so I can't say for sure.
Old September 15th 2003, 16:16
Its true that shared parts between a Beetle and a Thing will have a 113 part number, but only if they are identical. CV joints are not the same. Even if they were the same as a Type 4 CV, they'd have a 411 number or a 181 number, never a 113 number.
Old September 15th 2003, 16:31
Well, I guess both my supplier's catalog, as well as other companies (such as Things Unlimited and the Thing Shop) are wrong.
So, does anyone need a pair of oversize CV joints with a 113 part number that will fit a Thing?
Old September 16th 2003, 05:47
You are right that The Thing Shop has the wrong numbers. I looked up their listing of Thing drive flanges, and they quote 113 517 283U. If you wanted Type 181 flanges would you buy this one? How do you know its a T181 and not a Beetle flange?
