Old October 5th 2009, 18:47
vdubzack's Avatar
vdubzack vdubzack is offline
1.8 Type four(4)
Rebuilt 1.8l type 4 based engine. $2000. Oem Mahle barrels and pistons. Gotze rings Scat c45 cam new scat lifters, with .030 oil hole. To help lube the cam lobes.Chrome-moly push rods Rimco rebuilt and balanced rods. Kolbeshmit Main and cam bearings Mahle rod bearings. Rebuilt heads and polished crank. Will also come with, lightweight 200mm flywheel for upright conversion. You will only need cooling system, intake system exhaust and clutch to have a turn key. But Not Included. But can be purchased at a discount if purchased together. Will be built to order. Can be done as turn-key for $3568. With Dual 40 Weber, CSP upright cooling and custom exhaust from A1 kenedy 1700lb pressure plate with 200mm dual friction disc
