Old November 18th 2012, 14:07
dub_crazee's Avatar
Something a bit different! WARNING: CONTAINS FORD
Thought id share this with you guys as its kind of race inspired.So this week I've been working on something a bit different to the usual rusty vws I seem to get in. My friend always had capris when we were younger and used to go cruising round local towns. He took a break for a while but got another Capri last year which I did some metal work on. Well he came down this week with a but of a crazy plan. 5 link rear suspension, convert the front struts to coilovers and fit a great big 4.8L Chevy v8 (LR4) with a 6speed manual dodge viper gearbox.
Wheezy pinto
Strut off, bottom cup needs to be removed
Conversion tube and gaz insert
Conversion tube welded in
Both done
Fitted back up
Adjustable top mount
Classic Car Revivals
www.classiccarrevivals.com
Old November 18th 2012, 14:15
dub_crazee's Avatar
Onto the rear then. These anti roll bar mounts need to come off
4 link brackets tacked in
Had to get these bushes made for the rose joints
The kit is for an escort so the rear boxes need a lot of trimming
Rods need shortening too
Sleeved for strength
Old November 18th 2012, 14:25
dub_crazee's Avatar
Boxes welded in
Rods bolted in
m
Brackets fully welded including panard bracket
Panard rod fitted
Coilovers fitted
Old November 18th 2012, 19:14
dub_crazee's Avatar
And on to the engine. The 1.6 pinto was removed and engine mounts removed from cross member
Battery tray and radiator mounting panels were removed for space
Started chopping the tunnel and bulkhead out.....this hole got bigger
Trail fit with bell housing fitted
Next we attached the gearbox and levelled the engine/box combo up
Huuuuge
Tacking the engine mounts together
Old November 18th 2012, 19:22
dub_crazee's Avatar
All welded up
Mocking up the gearbox mount with spacers. A proper mount will replace this now we've worked out the height it needs to be
Love that huge throttle body
Still have to stitch the tunnel back together!!
Probably wont come back to this for a couple of weeks but hope some of you found it interesting and not too disturbing being a Ford!!!
Old November 18th 2012, 22:07
Looks great! You got the "mad fab skillz" going on!
Old November 19th 2012, 02:05
Nice work! More fab than I've seen on this forum for a long time! Keep us posted.
Old November 19th 2012, 12:57
dub_crazee's Avatar
Thanks guys,
I really enjoyed it last week - made a welcomed change! Plus it was nice to have Rob in the workshop.
Once ive stitched the tunnel back together, ive got to sort the metalwork around the shifter AND move the handbrake lever back lol. I think it;s going to have to go back about 4" which means Rob will have to get some custom cables made. Also have to modify the bonnet to clear the throttle body and alternator.
The car will then go back to Robs for Fuel/eletrics/cooling system and suspension set up.
He's going to have a custome xhaust made for it too as the header doesnt clear the steering column on the driver side.
As i say, not everyones cup of tea, but makes for a nice change.
Old November 19th 2012, 16:34
owdlvr's Avatar
owdlvr owdlvr is offline
Nice!
Definitely keep the updates coming...please.
'71 Type 1 - Rally Project
'75 Type 1 - Family Heirloom
Old April 19th 2013, 14:25
owdlvr's Avatar
This thread deserves an update...
Old April 22nd 2013, 16:15
dub_crazee's Avatar
Hey Dave,
funny you drag this thread up again as the car sat there for nearly 6 months......but i spent last week on it!!!
My work is now done. I welded in a brace for the panard rod mount, welded in a rear strut brace/harness mount. Welded in some seat bars. Fitted flywheel/clutch and custom prop. Raised the tunnel by 4 inches and finished off the bulkhead. Also, rob decided to go with an LS1 inlet manifold, alternator and waterpump.....which drops the throttle body by 4 inches. unfortunately he decided this AFTER we cut a ****ing huuge hole in the bonnet to make a bulge!!!
il get some pics up when ive uploaded them!!
the car is now heading back to Rob's for him to install the hydro clutch, cooling and fueling system. Then it's time to rock
Old May 12th 2013, 07:03
dub_crazee's Avatar
bit late....but theyre not the most thrilling pics
brace for the panard rod bracket
raising the tunnel by nearly 4 inches! Didn't just want to box it in - wanted to try and make it look as factory as possible
seat bars going in
rear strut bar/harness mounting bar also welded in
water pump/housing/alternator mount and bottom pulley all changed to allow the shorter inlet manifold. everything will now sit under a stock bonnet - this thing is going to be a real sleeper
so thats me done on it...the car is now back with rob....cooling/fueling systen and wiring left....cant wait to see it on the road!
Old October 2nd 2013, 14:11
dub_crazee's Avatar
So time for another Ford update. Rob was having difficulty finding a reasonably prices exhaust fab company....he was looking around the £2,500 mark for a set up....so i suggest we fab'd up a system for him. Next thing i know he's turned up with the car on a trailer and a load of stainless tube
One box and some tube
Had to modify one of the lovely new manifolds to clear the steering column/starter motor
After making the full system, we cut it in half and welded on these awesome clamp ends. i've not used them before but i'm well impressed!
That's 3 1/2 inches!
also welded up the hole in the bonnet!
Hoping the new fuel reg will turn up in the morning, need to prep and paint the bonnet and set the tracking - then MOT time
just uploading a short video of the engine running
Old October 2nd 2013, 14:38
dub_crazee's Avatar
http://s1104.photobucket.com/user/cl...035fa.mp4.html
Old October 3rd 2013, 12:49
moonska moonska is offline
That things going to be a animal! Good work Deano
